[postgis-users] reverse_geocode() specific error at specificgeom point
Barry McCall barry.mccall+postgis at gmail.com
Tue Oct 7 07:23:10 PDT 2014
I'm seeing with more clarity now.
After running
SELECT * FROM addr
WHERE fromhn ~* '[a-zA-Z]'
AND tohn ~* '[a-zA-Z]'
it returns 381,739 results with chars in fromhn and tohn.  Your message
came in where you stated
'It was caused by a record not being emitted but that gets the function
applied.'
Being new and still learning the system I'm assuming there is a function
that should be omitting any non integer/numerical values from these columns?
On Tue, Oct 7, 2014 at 10:07 AM, Barry McCall <
barry.mccall+postgis at gmail.com> wrote:
> Check out this lil guy right here :-)
> SELECT * FROM tiger_data.nc_addr
> WHERE tlid = '72088154'
> On Tue, Oct 7, 2014 at 10:06 AM, Barry McCall <barry.mccall at gmail.com>
> wrote:
>> Check out this lil guy :-)
>> On Tue, Oct 7, 2014 at 9:57 AM, Paragon Corporation <lr at pcorp.us> wrote:
>>>  Barry,
>>> applied.
>>> I put in a patch for this issue for 2.1 and 2.2 branch.  You just have
>>> to replace your reverse_geocode function with the one referenced in this
>>> ticket
>>> http://trac.osgeo.org/postgis/ticket/2958
>>> On a slgihtly related note, I noticed this address geocodes to
>>> 1,Greenwood  for location instead of just Greenwood.
>>> That is caused because the tiger_data.nc_cousub table has a bunch of 1s
>>> etc to denote township number I guess.  Not sure why they did that.
>>> if you want to get rid of those numbers, update the name field in
>>> tiger_data.nc_cousub.
>>> I forget why I use cousub instead of something else.
>>> Hope that helps,
>>> Regina
>>> http://www.postgis.us
>>> http://postgis.net
>>> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
>>> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Barry McCall
>>> *Sent:* Tuesday, October 07, 2014 8:17 AM
>>> *To:* PostGIS Users Discussion
>>> *Subject:* Re: [postgis-users] reverse_geocode() specific error at
>>> specificgeom point
>>>  The change from
>>> to_number(fromhn, '999999') As fromhn, to_number(tohn, '999999') As tohn
>>> to
>>> fromhn, tohn
>>> does work when I change it in the debug code. When I update the function
>>> it spits out the error below:
>>>  ERROR:  operator does not exist: character varying - character varying
>>> LINE 1: ...ate_Point(var_redge.line, var_pt)*(var_redge.tohn -
>>> var_redg...
>>> HINT:  No operator matches the given name and argument type(s). You
>>> might need to add explicit type casts.
>>> QUERY:  SELECT (var_redge.fromhn + ST_Line_Locate_Point(var_redge.line,
>>> var_pt)*(var_redge.tohn - var_redge.fromhn))::numeric(10)
>>> CONTEXT:  PL/pgSQL function reverse_geocode(geometry,boolean) line 157
>>> at assignment
>>> ********** Error **********
>>> SQL state: 42883
>>> Hint: No operator matches the given name and argument type(s). You might
>>> Context: PL/pgSQL function reverse_geocode(geometry,boolean) line 157 at
>>> assignment
>>> On Tue, Oct 7, 2014 at 7:24 AM, Paragon Corporation <lr at pcorp.us> wrote:
>>>>  I was able to replicate the error by loading NC data.
>>>> The problem is with the NULL address range records (coming from those
>>>> unnamed streets) I think.  I'll try to have a fix later today.
>>>> If you take change
>>>> to
>>>> fromhn, tohn
>>>> in the debug query
>>>> you should see records come back
>>>> *Sent:* Monday, October 06, 2014 6:03 PM
>>>> *To:* postgis-users at lists.osgeo.org
>>>> *Subject:* [postgis-users] reverse_geocode() specific error at
>>>> specific geom point
>>>>   For some reason when I reverse_geocode geometry point
>>>> 0101000020AD10000095D4096822CC53C08A1F63EE5AAA4140
>>>> it returns error
>>>>  ERROR:  invalid input syntax for type numeric: " "
>>>> SQL state: 22P02
>>>> I performed UPDATE tiger.geocode_settings SET setting = 'true' WHERE
>>>> name = 'debug_reverse_geocode'; to try to get a grasp of what was going on;
>>>> however, there are so many CTEs in the debug I cant get a grasp of what is
>>>> really happening.
>>>> Does anyone familiar with this system know why this is throwing this
>>>> error? It seems to only happen with lon,lat around -79.1866 35.3309.
>>>> SELECT r.addy[1] FROM reverse_geocode(ST_GeomFromText('POINT(-79.1866
>>>> 35.3309)',4269),true) AS r
>>>> NOTICE:  Statement 1:
>>>>     WITH ref AS (
>>>>         SELECT
>>>> '0101000020AD10000095D4096822CC53C08A1F63EE5AAA4140'::geometry As ref_geom
>>>> f AS
>>>> ( SELECT faces.* FROM faces  CROSS JOIN ref
>>>> WHERE faces.statefp = '37' AND faces.countyfp = '105'
>>>> AND ST_Intersects(faces.the_geom, ref_geom)
>>>> e AS
>>>> ( SELECT edges.tlid , edges.statefp, edges.the_geom, CASE WHEN
>>>> edges.tfidr = f.tfid THEN 'R' WHEN edges.tfidl = f.tfid THEN 'L' ELSE NULL
>>>> END::varchar As eside,
>>>>                     ST_ClosestPoint(edges.the_geom,ref_geom) As
>>>> center_pt, ref_geom
>>>> FROM edges INNER JOIN f ON (f.statefp = edges.statefp AND (edges.tfidr
>>>> = f.tfid OR edges.tfidl = f.tfid))
>>>>     CROSS JOIN ref
>>>> WHERE edges.statefp = '37' AND edges.countyfp = '105'
>>>> AND ST_DWithin(edges.the_geom, ref.ref_geom, 0.01) AND (edges.mtfcc
>>>> LIKE 'S%') --only consider streets and roads
>>>> ea AS
>>>> (SELECT e.statefp, e.tlid, a.fromhn, a.tohn, e.center_pt, ref_geom,
>>>> a.zip, a.side, e.the_geom
>>>> FROM e LEFT JOIN addr As a ON (a.statefp = '37'  AND e.tlid = a.tlid
>>>> and e.eside = a.side)
>>>> SELECT *
>>>> FROM (SELECT DISTINCT ON(tlid,side)  foo.fullname, foo.streetname,
>>>> foo.streettypeabbrev, foo.zip,  foo.center_pt,
>>>>   side, to_number(fromhn, '999999') As fromhn, to_number(tohn,
>>>> '999999') As tohn, ST_GeometryN(ST_Multi(line),1) As line,
>>>>    dist
>>>> FROM
>>>>   (SELECT e.tlid, e.the_geom As line, n.fullname, COALESCE(n.prequalabr
>>>> || ' ','')  || n.name
>>>>  AS streetname, n.predirabrv, COALESCE(suftypabrv, pretypabrv) As
>>>> streettypeabbrev,
>>>>       n.sufdirabrv, e.zip, e.side, e.fromhn, e.tohn , e.center_pt,
>>>>  ST_Distance_Sphere(ST_SetSRID(e.center_pt,4326),ST_SetSRID(ref_geom,4326))
>>>> As dist
>>>> FROM ea AS e
>>>> LEFT JOIN (SELECT featnames.* FROM featnames
>>>>     WHERE featnames.statefp = '37'   ) AS n ON (n.statefp =  e.statefp
>>>> AND n.tlid = e.tlid)
>>>> ORDER BY dist LIMIT 50 ) As foo
>>>> ORDER BY foo.tlid, foo.side,  CASE 0 WHEN 0 THEN 0  WHEN 1 THEN CASE
>>>> WHEN foo.fullname ~ '[0-9]+' THEN 0 ELSE 1 END ELSE CASE WHEN foo.fullname
>>>> > '' AND NOT (foo.fullname ~ '[0-9]+') THEN 0 ELSE 1 END END ,
>>>>  foo.fullname ASC NULLS LAST, dist LIMIT 50) As f ORDER BY f.dist, CASE
>>>> WHEN fullname > '' THEN 0 ELSE 1 END
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141007/3bffeb9c/attachment.html>
