[postgis-users] ST_Split just doesn't work for me.
Rémi Cura
remi.cura at gmail.com
Fri Oct 17 14:53:22 PDT 2014
Your querry doesn't handle properly the case when one line has to be split
by multiple other lines.
a simple list
_are the geom valid (ST_ISValid / ST_MakeValid)
_are the geom in the same referential
_do you have a recent postgis/geos version (postgis_full_version())
_are you geometry at the correct precision (st_snaptogrid())
Cheers,
Rémi-C
2014-10-17 22:23 GMT+02:00 <Alexander.Mahrou at ch2m.com>:
> Hello List,
> I’ve got two polyline tables. I’m attempting to segment my lines by the
> intersections of the other lines.
> create table segments as SELECT
> ST_CollectionExtract(ST_Split(a.newgeom,b.geom),2) as geom from
> line1 a, line2 b WHERE ST_Intersects(a.newgeom,b.geom) =
> true
> The end result is the geometry that I started with. What am I doing wrong?
> *Alex Mahrou*
> *Oil, Gas & Chemicals*
> *CH2**M HILL*
> 9191 S. Jamaica St.
> Englewood, CO 80112
> www.ch2m.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141017/46de1242/attachment.html>
