[postgis-users] Oriented BBox Efficient computing?
Sandro Santilli strk at keybit.net
Thu Oct 23 07:37:24 PDT 2014
On Thu, Oct 23, 2014 at 04:33:05PM +0200, Rémi Cura wrote:
> Hm I don't understand.
> The point is to get this bouding rectangle axis.
> So why compute convex hull?
If you had to use your initial rotate & try approach, taking
the convexhull would reduce the cost of rotation.
--strk;
> Cheers,
> Rémi-C
> 2014-10-23 16:23 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> > On Thu, Oct 23, 2014 at 04:15:06PM +0200, Rémi Cura wrote:
> > > _I'm precisely looking for 2 axis (convex hull is excluded then)
> > I don't see how any bounding rectangle could touch vertices
> > that are not part of the convex hull.
> > --strk;
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
