[postgis-users] Oriented BBox Efficient computing?
Rémi Cura
remi.cura at gmail.com
Thu Oct 30 12:13:21 PDT 2014
A first raw plpgsql implementation :
"Loop" on all angle from convex hull edge.
https://github.com/Remi-C/PPPP_utilities/blob/master/postgis/rc_oriented_bbox_deom_axis.sql
Cheers,
Rémi-C
2014-10-25 17:06 GMT+02:00 Rémi Cura <remi.cura at gmail.com>:
> Of course I plan to use convex hull,
> I didn't put it because I can call it at plpgsql level so I consider it to
> be "free".
> Cheers,
> Rémi-C
> 2014-10-25 16:15 GMT+02:00 Åsmund Tokheim <asmundto at gmail.com>:
>> Convex hulls are not only needed as a performance boost. You would need
>> some complicated "find next extreme point"-code in order for the algorithm
>> to behave correctly as well.
>> Åsmund
>> On Sat, Oct 25, 2014 at 3:41 PM, Stephen Woodbridge <
>> woodbri at swoodbridge.com> wrote:
>>> And if you do that on the convex hull rather than the original geometry,
>>> you will have less points to consider while doing the evaluation.
>>> -Steve
>>> On 10/25/2014 8:52 AM, Rémi Cura wrote:
>>>> Found a python version here for minimal area enclosing rectangle
>>>> http://docs.opencv.org/modules/imgproc/doc/
>>>> structural_analysis_and_shape_descriptors.html#minarearect
>>>> It takes a numpy 2D array as point
>>>> That means it is possible to use shapely to read postgis wkb geom, then
>>>> convert it to numpy and use opencv afterward.
>>>> There is also this implementation in python (iterate over all possible
>>>> edge angle)
>>>> https://github.com/dbworth/minimum-area-bounding-
>>>> rectangle/blob/master/python/min_bounding_rect.py
>>>> To implement rotating caliper,
>>>> I would need some functions like :
>>>> - compute robust orientation of an edge (easy)
>>>> - loop on points (should be provided)
>>>> - area of a rectangle defined by 4 points and 1 angle (=2 caliper
>>>> sets) (easy)
>>>> I guess using only the geos_c.h api is not a good solution.
>>>> Where should I look in the cpp geos jungle?
>>>> Cheers,
>>>> Rémi-C
>>>> 2014-10-25 2:23 GMT+02:00 Åsmund Tokheim <asmundto at gmail.com
>>>> <mailto:asmundto at gmail.com>>:
>>>> As far as I can tell, you shouldn't order and rotate, or you'll be
>>>> looking at a O(n^2) implementation. During an iteration of
>>>> http://cgm.cs.mcgill.ca/~orm/rotcal.html
>>>> <http://cgm.cs.mcgill.ca/%7Eorm/rotcal.html>, it seems like you can
>>>> make the following assumptions:
>>>> The next angle you should rotate to will be one of the four angles,
>>>> given by the current extreme points and their next clockwise
>>>> neighbour. So you should be able to find the next minimum clockwise
>>>> rotation in O(1) time
>>>> Also whenever you do a clockwise rotation to orient one of the
>>>> support lines along a new edge, the extreme points for the other
>>>> support lines stay the same. You only need to update the extreme
>>>> point that was on the edge we now use as a support line, to its next
>>>> clockwise point. Using the new extreme points and caliper's angle,
>>>> you can calculate the bbox area in O(1) time as well.
>>>> Regards
>>>> Åsmund
>>>> On Fri, Oct 24, 2014 at 7:09 PM, Rémi Cura <remi.cura at gmail.com
>>>> <mailto:remi.cura at gmail.com>> wrote:
>>>> Ok if I understand right,
>>>> implementing it at the sql level would be :
>>>> - compute convex envelop
>>>> - order edges by angle
>>>> - round angle to a given precision, keep distinct values
>>>> - for each angle, rotate and compute bbox and area
>>>> keep bbox and rotation giving the min area.
>>>> Cheers,
>>>> Rémi-C
>>>> 2014-10-23 18:46 GMT+02:00 Stephen V. Mather
>>>> <svm at clevelandmetroparks.com <mailto:svm@
>>>> clevelandmetroparks.com>>:
>>>> That would be really cool. Could be a set of functions. It
>>>> would be interesting to see if the triangulation
>>>> optimizations listed at
>>>> <http://cgm.cs.mcgill.ca/%7Eorm/rotcal.html> are faster
>>>> than
>>>> the JTS/GEOS equivalents.
>>>> Stephen V. Mather
>>>> GIS Manager
>>>> (216) 635-3243 <tel:%28216%29%20635-3243> (Work)
>>>> clevelandmetroparks.com <http://clevelandmetroparks.com>
>>>> ________________________________________
>>>> From: postgis-users-bounces at lists.osgeo.org
>>>> <mailto:postgis-users-bounces at lists.osgeo.org>
>>>> <postgis-users-bounces at lists.osgeo.org
>>>> <mailto:postgis-users-bounces at lists.osgeo.org>> on behalf
>>>> of
>>>> Sandro Santilli <strk at keybit.net <mailto:strk at keybit.net>>
>>>> Sent: Thursday, October 23, 2014 12:36 PM
>>>> To: PostGIS Users Discussion
>>>> Subject: Re: [postgis-users] Oriented BBox Efficient
>>>> computing?
>>>> On Thu, Oct 23, 2014 at 06:17:56PM +0200, Rémi Cura wrote:
>>>> > Wov thanks everybody :
>>>> > Seems it possible to do it fully geometrically :
>>>> Nice, would be a good candidate for a new PostGIS function
>>>> (possibly via JTS/GEOS)
>>>> --strk;
>>>> () Free GIS & Flash consultant/developer
>>>> /\ http://strk.keybit.net/services.html
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> <mailto:postgis-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-
>>>> users
>>>> users
>>>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.
>>>> osgeo.org>
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141030/7eb49772/attachment.html>
