[postgis-users] PostGIS 2.1.4 release
Paragon Corporation
lr at pcorp.us
Wed Sep 10 20:33:08 PDT 2014
The 2.1.4 release of PostGIS is now available.
The PostGIS development team is happy to release patch for PostGIS 2.1, the
2.1.4 release. As befits a patch release, the focus is on bugs, breakages,
and performance issues
Download source code here:
http://download.osgeo.org/postgis/source/postgis-2.1.4.tar.gz
Html docs: http://download.osgeo.org/postgis/docs/doc-html-2.1.4.tar.gz ,
PDF docs: http://download.osgeo.org/postgis/docs/postgis-2.1.4.pdf
Enhancements
#2745, Speedup ST_Simplify calls against points
#2747, Support for GDAL 2.0
#2749, Make rtpostgisupgrade20_21.sql ACID
#2811, Do not specify index names when loading shapefiles/rasters
#2829, Shortcut ST_Clip(raster) if geometry fully contains the raster
and no NODATA specified
#2895, Raise cost of ST_ConvexHull(raster) to 300 for better query plans
Bug Fixes
#2605, armel: _ST_Covers() returns true for point in hole
#2911, Fix output scale on ST_Rescale/ST_Resample/ST_Resize of rasters
with scale 1/-1 and offset 0/0.
Fix crash in ST_Union(raster)
#2704, ST_GeomFromGML() does not work properly with array of gml:pos
(Even Roualt)
#2708, updategeometrysrid doesn't update srid check when schema not
specified. Patch from Marc Jansen
#2720, lwpolyaddring should update maxrings after realloc
#2759, Fix postgis_restore.pl handling of multiline object comments
embedding sql comments
#2774, fix undefined behavior in ptarraycalculategbox_geodetic
Fix potential memory fault in ST_MakeValid
#2784, Fix handling of bogus argument to -with-sfcgal
#2772, Premature memory free in RASTER_getBandPath (ST_BandPath)
#2755, Fix regressions tests against all versions of SFCGAL
#2775, lwlinefromlwmpoint leaks memory
#2802, ST_MapAlgebra checks for valid callback function return value
#2803, ST_MapAlgebra handles no userarg and STRICT callback function
#2834, ST_Estimated_Extent and mixedCase table names (regression bug)
#2845, Bad geometry created from ST_AddPoint
#2870, Binary insert into geography column results geometry being
inserted
#2872, make install builds documentation (Greg Troxell)
#2819, find isfinite or replacement on Centos5 / Solaris
#2899, geocode limit 1 not returning best answer (tiger geocoder)
#2903, Unable to compile on FreeBSD
#2927 reverse_geocode not filling in direction prefix (tiger geocoder)
get rid of deprecated ST_Line_Locate_Point called
For more details refer to:
http://trac.osgeo.org/postgis/query?status=closed&groupdesc=1&group=priority
&milestone=PostGIS+2.1.4&order=priority
Happy PostGISsing,
