[postgis-users] Questions related to some tests I did in PostGIS
DanielFranco
dfranco at computacao.ufla.br
Fri Sep 19 19:54:59 PDT 2014
Thank you for your reply.
I've only showed the 5x5 pixels results.
I've tried to use out-db rasters some time ago and an error like
"rt_band_load_offline_data: Cannot open >> offline raster" appeared when I
tried to acess them in functions like ST_Value, but I still could acess all
the metadata.
Could you give me an example of PostGIS raster applied to longitudinal data?
Thanks.
View this message in context: http://postgis.17.x6.nabble.com/Questions-related-to-some-tests-I-did-in-PostGIS-tp5007007p5007017.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
