[postgis-users] PostGIS supported by which ArcGIS
Randal Hale
rjhale at northrivergeographic.com
Sat Sep 27 11:20:23 PDT 2014
as far as I understand it (and I could be wrong on some of this)
* Desktop will support reading if you load the postgresql library
files (that can be downloaded form your ESRI customer care portal).
* Once those are loaded you can read through a definition query data
from postgis into arcgis. I just made a map using arcgis and reading
data from postgis.
* It doesn't support write unless you have SDE for Postgresql - which
isn't postgis. That dives into the world of ArcGIS Server....
ArcGIS supposedly is moving to being able to read/write the geopackage
format which to me opens read/write to PostGIS. BUT if they open read
write for postgis that starts a slow death of SDE....so I don't believe
it ever will (for the foreseeable future).
Randy
On 09/27/2014 02:10 PM, Stefan Keller wrote:
> I'm asked from time to time for an advice which ArcGIS product
> supports PostGIS (read/write)?
> Even after reading the Esri pages I'm not sure if it's only "ArcGIS
> for Server Workgroup" (formerly ArcSDE).
> Does it work also with ArcGIS for Desktop Basic (ArcView)?
> Yours, S.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/spatial-connect
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140927/4c4e1158/attachment.html>
