[postgis-users] Fwd: Partitionning using geometry
Rémi Cura remi.cura at gmail.com
Thu Apr 2 02:09:12 PDT 2015
Hey Nicolas,
great answer.
At least it gives some hope,
because it is possible to compute value in plpgsql function and create on
the fly a querry with those values hard written.
I still don't know if it would work with geometry tough
Thanks,
Rémi-C
2015-04-02 10:59 GMT+02:00 Nicolas Ribot <nicolas.ribot at gmail.com>:
> Hi Remy,
> As far as I understood table partitionning has one limiting caveat for
> some usages (from:
> http://www.postgresql.org/docs/9.4/static/ddl-partitioning.html):
> "Constraint exclusion only works when the query's WHERE clause contains
> constants (or externally supplied parameters). For example, a comparison
> against a non-immutable function such as CURRENT_TIMESTAMP cannot be
> optimized, since the planner cannot know which partition the function value
> might fall into at run time."
> Here are the plans of your query using function for check constraint, then
> using constant values:
> The second plan shows partionning is used, not in the first:
> -- fonctions as check parameters:
> explain SELECT *
> FROM  test_father , ST_Buffer(ST_MakePoint(5,5),1) as buf
> WHERE
>     ST_X(geom) BETWEEN ST_XMin(buf) AND ST_Xmax(buf)
>     AND ST_Y(geom) BETWEEN ST_YMin(buf) AND ST_Ymax(buf);
> "Nested Loop  (cost=0.00..1206.78 rows=219 width=68)"
> "  Join Filter: ((st_x(test_father.geom) >= st_xmin((buf.buf)::box3d)) AND
> (st_x(test_father.geom) <= st_xmax((buf.buf)::box3d)) AND
> (st_y(test_father.geom) >= st_ymin((buf.buf)::box3d)) AND
> (st_y(test_father.geom) <= st_ymax((buf.buf)::box3d)))"
> "  ->  Function Scan on buf  (cost=0.00..0.01 rows=1 width=32)"
> "  ->  Append  (cost=0.00..321.12 rows=17713 width=36)"
> "        ->  Seq Scan on test_father  (cost=0.00..0.00 rows=1 width=36)"
> "        ->  Seq Scan on test_child_1  (cost=0.00..151.64 rows=8364
> width=36)"
> "        ->  Seq Scan on test_child_2  (cost=0.00..169.48 rows=9348
> width=36)"
> -- constants as check parameters:
> explain SELECT *
> WHERE  -- hard coded values
>     ST_X(geom) BETWEEN 4 and 6
>     AND ST_Y(geom) BETWEEN 4 and 6 ;
> "Nested Loop  (cost=0.00..318.95 rows=2 width=68)"
> "  ->  Append  (cost=0.00..318.92 rows=2 width=36)"
> "              Filter: ((st_x(geom) >= 4::double precision) AND
> (st_x(geom) <= 6::double precision) AND (st_y(geom) >= 4::double precision)
> AND (st_y(geom) <= 6::double precision))"
> "        ->  Seq Scan on test_child_1  (cost=0.00..318.92 rows=1 width=36)"
> The test_child2 table is excluded in this plan.
> Nicolas
> On 2 April 2015 at 10:12, Rémi Cura <remi.cura at gmail.com> wrote:
>> In theory, they use check for partitionning.
>> It is possible (but inneficient) that check will overlaps (they give one
>> such example in doc).
>> Thus you can partition into tables that may have some common space.
>> This is the theory.
>> I don't understand why it doesn't work, and I got no answers from
>> postgres mailing list.
>> Cheers,
>> Rémi-C
>> 2015-04-01 23:01 GMT+02:00 Stephen V. Mather <svm at clevelandmetroparks.com
>>>  Hi,
>>>  Can you reliably partition with anything other than points? I thought
>>> Postgres hadn't implemented ranges appropriately for the inevitable
>>> linestring or polygon that crosses a partition boundary. (Fuzzy 2-year-old
>>> memories, so perhaps something has changed...).
>>>  Cheers,
>>> Best,
>>> Steve
>>>     [image: http://sig.cmparks.net/cmp-ms-90x122.png] *Stephen V.
>>> Mather*
>>> GIS Manager
>>> (216) 635-3243 (Work)
>>> clevelandmetroparks.com <http://www.clemetparks.com>
>>> *From:* postgis-users-bounces at lists.osgeo.org <
>>> postgis-users-bounces at lists.osgeo.org> on behalf of Rémi Cura <
>>> *Sent:* Wednesday, April 1, 2015 12:03 PM
>>> *To:* PostGIS Users Discussion
>>> *Subject:* [postgis-users] Fwd: Partitionning using geometry
>>>  (cross-post from postgres list)
>>>     Hey dear list,
>>>  I'd like to partition geographical (geometry) data with postgres
>>> mechanism.
>>>  (my usage is in fact related to pointcloud, but I use geometry as a
>>> work around)
>>>  From example I read on constraint, nothing should prevent it from
>>> working
>>>  Here is a self contained example, the planner doesn"t seems to use the
>>> constraint_exclusion mechanism, whatever the constraint
>>>  Thanks,
>>>  Cheers,
>>>  Rémi-C
>>> CREATE SCHEMA IF NOT EXISTS test_partitionning;
>>> SET search_path TO test_partitionning, public ;
>>> DROP TABLE IF  EXISTS test_father CASCADE;
>>> CREATE TABLE test_father  (
>>>     gid SERIAL PRIMARY KEY
>>>     , geom geometry
>>> create table test_child_1 (
>>>     check (geometry_overlaps(geom,ST_Expand(ST_MakePoint(10,10),10  ) ) )
>>>     ,check ( geom&&ST_Expand(ST_MakePoint(10,10),10  ) )
>>>     , CHECK (ST_X(geom) BETWEEN 0 AND 20)
>>>     , CHECK (ST_Y(geom) BETWEEN 0 AND 20)
>>>     , CHECK (  ST_Intersects(geom, ST_Expand(ST_MakePoint(10,10),10  ))
>>> ) inherits (test_father);
>>> --CREATE INDEX ON test_child_1 USING GIST(geom);
>>> create table test_child_2 (
>>>     check (geometry_overlaps(geom,ST_Expand(ST_MakePoint(30,10),10  ) ) )
>>>     ,check ( geom&&ST_Expand(ST_MakePoint(30,10),10  ) )
>>>     , CHECK (ST_X(geom) BETWEEN 20 AND 40)
>>>     , CHECK (  ST_Intersects(geom, ST_Expand(ST_MakePoint(30,10),10  ))
>>> --CREATE INDEX ON test_child_2 USING GIST(geom);
>>> INSERT INTO test_child_1 (geom)
>>> SELECT ST_MakePoint(s1/10.0+random(),s2/10.0+random())
>>> FROM generate_series(1,90) AS s1, generate_series(1,90) AS s2;
>>> INSERT INTO test_child_2 (geom)
>>> FROM generate_series(200,300) AS s1, generate_series(1,90) AS s2;
>>> SHOW constraint_exclusion;
>>> SET constraint_exclusion TO partition;
>>> WITH area_of_interest AS (
>>>     SELECT ST_Buffer(ST_MakePoint(5,5),1) as buf
>>> SELECT *
>>> FROM area_of_interest, test_father
>>> WHERE  -- geom && buf
>>>     AND ST_Y(geom) BETWEEN ST_YMin(buf) AND ST_Ymax(buf) ;
>>> SELECT *
>>> WHERE
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150402/6a5a301a/attachment.html>
