[postgis-users] Inserting column from another table
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Thu Apr 2 08:42:51 PDT 2015
All,
Oh, geez, I just realized I wrote my answer using syntax from two different functions.
It should have been more like what Dylan responded with . . . sorry to introduce confusion . . .
Bobb
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Daniel GIL
Sent: Thursday, April 02, 2015 10:33 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Inserting column from another table
Hi Dylan. It worked. I thought I tried that yesterday but I probably did something wrong.
Thank you very much for your answers,
Regards,
Daniel
On Thu, Apr 2, 2015 at 11:00 AM, Dylan Adams <dylan.adams at gmail.com<mailto:dylan.adams at gmail.com>> wrote:
You'll need to use an UPDATE to accomplish what you're trying to do. It'll probably look something like this
UPDATE Table1
SET geom = Table2.geom
FROM Table2
WHERE Table1.FabID = Table2.FabID;
There's more information in the Postgres' documentation about the UPDATE statement:
http://www.postgresql.org/docs/9.4/interactive/sql-update.html
Regards,
dylan
On Thu, Apr 2, 2015 at 9:53 AM, Daniel GIL <dangimar at gmail.com<mailto:dangimar at gmail.com>> wrote:
Hello, I'm learning SQL/PostGIS and I need some help...
I have a table (Table1) with different fields (but no geometry field). This table has already 35 rows of values.
I imported a second Table to the same database in pgAdmin using pgShapeLoader. This second table has a geom field that I want to add to Table1. The idea is to convert a non-spatial table to spatial
I created a geom field in Table 1 using AddColumn:
SELECT AddGeometryColumn('UDE_spatial','public','table1','geom',4326,'POINT',2);
Now, I'm trying to add the values from geom field in Table 2 to geom field in Table 1:
INSERT INTO Table1(geom)
SELECT geom
FROM Table2;
There are 35 rows to add and a common field 'FabID'. My surprise is that instead of adding the values in the rows from 1 to 35, it starts in the row number 36. It seems like you only could use INSERT INTO...SELECT when you want to add fields to a new table with no values added yet. I don't know how to write the sentence in the way I need. I tried adding...WHERE fabid BETWEEN 1 AND 35.
Well, that's probably a very simple question for most of you but I'm getting crazy...lol
Thanks
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150402/bf2fddb7/attachment.html>
