[postgis-users] Partitioning using Geometry
Brian M Hamlin maplabs at light42.com
Fri Apr 3 13:21:18 PDT 2015
I have implemented this in the past, with "millions of features" ...
for land use classification in California..
given a reference topological set.. each polygon in the topology gets
an ID, each POINT is assigned to one and only one poly ID
partition on the poly *id* -- no geometry expression in the check constraints
Improvements to the method include weighting, and combining sparse buckets
worked great ..   -Brian
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150403/83dd5f1b/attachment.html>
