[postgis-users] Equality operator for type box2d
Nick Ves vesnikos at gmail.com
Tue Apr 21 22:26:12 PDT 2015
Ah yes thank you for clearing that up. The = Operator is valid for those type.
Strange thing is that box2d type DOES support the = Operator while
st_box2d does not.
A quick search in gis.SE forums gives a post [0] from a user stating
that st_box2d is deprecated? Is that the case?
[0] http://gis.stackexchange.com/questions/56818/st-box2d-in-postgis-2-0
On Tue, Apr 21, 2015 at 1:24 PM, Kuien Liu <kliu at pivotal.io> wrote:
> thanks, got it. Surely you may meet this issue, distinct cannot find the
> 'OPERATOR =' for data type 'box2d'.
> PostGIS only supports 3 kinds of OPERATOR =, i.e.,
> OPERATOR =  (geometry,geometry)
> OPERATOR =  (geography,geography)
> OPERATOR =  (raster,raster)
> Maybe we can try these ways:
> cast box2d to geometry: select distinct st_extent(the_geom)::geometry from
> test;
> create ordering operator for box2d.
> Cheers,
> Kuien Liu
> On Tue, Apr 21, 2015 at 6:06 PM, Nick Ves <vesnikos at gmail.com> wrote:
>> On Tue, Apr 21, 2015 at 12:50 PM, Kuien Liu <kliu at pivotal.io> wrote:
>> > I'm not sure I understand what your query really looks like, but I can
>> > run
>> > query below.
>> try this one:
>> select distinct st_extent(the_geom) over () from test;
>> > gis=# SELECT ST_GeometryType(ST_Extent(the_geom))='ST_Polygon' FROM test
>> > WHERE num < 10;
>> >  ?column?
>> >  true
>> > (1 row)
>> > where the table 'test' contains 50,000 points.
>> > Wish this helps to you.
>> > Cheers,
>> > Kuien Liu
>> > On Tue, Apr 21, 2015 at 4:58 PM, Nick Ves <vesnikos at gmail.com> wrote:
>> >> I was playing with the ST_Extent today and I wanted to try a query like
>> >> this:
>> >> select distinct ST_Extent(geom)  over () box from parcels_test
>> >> where the geom is Type ST_Polygon but I got this error instead:
>> >>   ERROR:  could not identify an equality operator for type box2d
>> >> The aim was to get the BBox from a set of polygons that might or might
>> >> not be adjutant. Ofc you can get the same results by limit the result
>> >> to 1 but, it hitted me strange box2d type not having an equal operator
>> >> using "POSTGIS="2.1.4 r12966" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel.
>> >> 4.8.0, 6 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24"
>> >> LIBXML="2.9.1" LIBJSON="UNKNOWN" RASTER"
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at lists.osgeo.org
>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
