[postgis-users] How to use UPDATE command with LIKE clause?
KhunSanAung
khunsanaung.gis at gmail.com
Wed Apr 29 01:36:32 PDT 2015
Hi All,
I've two tables with similar columns storing text values.
agriculture (name, code, geom)
town (name, code, geom)
I'd like to run the UPDATE geom column for a string columns.
UPDATE public.agriculture SET
geom = towns.geom
FROM towns
FOR EACH ROW
WHERE agriculture."code" LIKE towns."code";
The problem here is the values of 'code' columns are not always exactly
the same.
agriculture.code sometimes contains additional text
So I've to use the LIKE command. e.g.
town.code = 'MMR013025'
agriculture.code = 'MMR013025*701*'
in that case I also like to have the values from towns aslo.
geom = towns.geom
FROM towns
FOR EACH ROW
WHERE agriculture."code" LIKE '*MMR013025*%'
What would be the right command to do it?
Thank you very much in advance.
Have a nice day!
*Mr. Khun San Aung*
* <http://geoportal.icimod.org/>*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150429/20fdfba4/attachment.html>
