[postgis-users] How to use UPDATE command with LIKE clause?
KhunSanAung khunsanaung.gis at gmail.com
Thu Apr 30 01:21:38 PDT 2015
Hi Hug,
That is helpful for me. Correction to the above command is;
UPDATE agriculture SET
geom = towns.geom
FROM towns
WHERE agriculture."code" LIKE towns."code"||'%';
Many thanks again & best regards
On Wed, Apr 29, 2015 at 5:42 PM, Hugues François <hugues.francois at irstea.fr>
wrote:
> Hello,
> It sounds more like a sql question than a postgis one but I think
> concatenate should helps:
> UPDATE public.agriculture SET
>         geom = towns.geom
>         FROM towns
> FOR EACH ROW
> HTH
> Hug
> -------- Message original --------
> De : KhunSanAung <khunsanaung.gis at gmail.com>
> Envoyé : Wednesday, April 29, 2015 10:37 AM
> À : postgis-users at lists.osgeo.org
> Sujet : [postgis-users] How to use UPDATE command with LIKE clause?
> Hi All,
> I've two tables with similar columns storing text values.
> agriculture (name, code, geom)
> town (name, code, geom)
> I'd like to run the UPDATE geom column for a string columns.
> geom = towns.geom
> FROM towns
> FOR EACH ROW
> WHERE agriculture."code" LIKE towns."code";
> ​The problem here is the values of 'code' columns​ are not always exactly
> the same.
> agriculture.code sometimes contains additional text
> So I've to use the LIKE command. e.g.
> town.code = 'MMR013025'
> agriculture.code = 'MMR013025*701*'
> ​in that case I also like to have the values from towns aslo.​
> ​​UPDATE public.agriculture SET
> geom = towns.geom
> FROM towns
> FOR EACH ROW
> WHERE agriculture."code" LIKE '*MMR013025*%'
> What would be the right command ​to do it?
> Thank you very much in advance.
> Have a nice day!
> *Mr. Khun San Aung*
> * <http://geoportal.icimod.org/>*
Have a nice day!
*Mr. Khun San Aung*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150430/39d6953f/attachment.html>
