[postgis-users] Is it possible to do constraint exclusion based on spatial extents?
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Aug 2 13:19:16 PDT 2015
Hi Remi,
So I got this far, without any success:
-- get the bbox for each table
select st_extent(geom) from rawdata.streets_91;
-- 'BOX(-87.60196 24.54513,-80.0323 31.00091)'
select st_extent(geom) from rawdata.streets_92;
-- 'BOX(-88.47265 30.2251,-80.84104 35.00732)'
select st_extent(geom) from rawdata.streets_93;
-- 'BOX(-84.32147 32.08265,-76.02063 36.58729)'
-- set the CHECK constraint (using diagonal line to define bbox)
ALTER TABLE rawdata.streets_91 ADD CONSTRAINT bbox_chk
CHECK (geom && st_setsrid('LINESTRING(-87.60196 24.54513,-80.0323
31.00091)'::text, 4326));
ALTER TABLE rawdata.streets_92 ADD CONSTRAINT bbox_chk
CHECK (geom && st_setsrid('LINESTRING(-88.47265 30.2251,-80.84104
35.00732)'::text, 4326));
ALTER TABLE rawdata.streets_93 ADD CONSTRAINT bbox_chk
CHECK (geom && st_setsrid('LINESTRING(-84.32147 32.08265,-76.02063
36.58729)'::text, 4326));
-- turn on constraint exclusion for union and inheritance
SET constraint_exclusion = partition;
explain select * from rawdata.streets where st_dwithin(geom,
st_setsrid('POINT(-84.414 33.883)'::geometry, 4326), 50.0/111120.0);
st_setsrid('POINT(-67.146 18.476)'::geometry, 4326), 50.0/111120.0);
st_setsrid('POINT(-81.777 24.558)'::geometry, 4326), 50.0/111120.0);
So only the first and third select should hit and they should only hit
one table based on constraint exclusion.
But I am not showing any checking of constraints in the explain output.
Maybe it is touchy about the way you set/test the constraints.
Anyone know if this is possible and how to set it up?
Thanks,
-Steve
On 8/2/2015 3:36 PM, Rémi Cura wrote:
> Hey,
> I asked this question to the postgres mailing list here:
> http://www.postgresql.org/message-id/CAJvUf_szgMLxC4=b6+AgY9HgyPaRes2JVb6bTKXiFF6CXa_epw@mail.gmail.com
> I would be very interested if you find a solution (I did not).
> Cheers,
> Rémi-C
> 2015-08-02 21:04 GMT+02:00 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>:
> Hi,
> I know I can setup table inheritance and constraint exclusion based
> on say the state field. But I would like to do this based on geom
> and the table extents. How would I do this?
> Say for example, I create a roads table, then load data into
> roads_area1, roads_area2, etc and these inherit from roads.
> For the state abbrv. I might have:
> ALTER TABLE roads_area1 ADD CONSTRAINT chk
> CHECK (state IN ('MA', 'ME', 'NH'));
> So doing the same based on geom column might look like:
> ALTER TABLE roads_area1 ADD CONSTRAINT bbox_chk
> CHECK (geom && <????>);
> So does this work?
> Do I need to do anything special to get postgresql to using
> constraint exclusion? What?
> How would I set <????>?
> These tables are create once and query often, so the extents are not
> changing after they are loaded.
> Thanks,
> -Steve W
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
