[postgis-users] How we get raster values
Tom van Tilburg tom.van.tilburg at gmail.com
Mon Aug 3 13:23:20 PDT 2015
Ahmet,
I think it is about the same question as I earlier answered for Juli.
I'm copy pasting it here, hope it helps:
You have to adapt it to your own circumstances ofcourse, but at the same
time I'd encourage you to read the documentation because it has samples
included.
Try to split your functionality with the help of 'WITH' statements and
see if you can do the grouping in that way in a subselect.
Something like:
WITH clips AS (
     SELECT p.ecoregion_cod, ST_Union(ST_Clip(r.rast,1, p.geom, true))
AS rast
     FROM gis_wd.wd_ecoregiones AS p, rastertmp.prova AS r
     WHERE ST_Intersects(r.rast, p.geom)
     GROUP BY ecoregion_cod --now you don't have to group by the raster
result itself
SELECT p.ecoregion_co, (ST_SummaryStats(rast, 1)).* FROM clips --this
should give you the stats per ecoregion_co
Best,
  Tom
On 7/31/2015 6:35 PM, Kishore raju wrote:
> I am trying to get pixels intersected in raster layer with polygons in
> vector layer. can you please help me in designing the query.
> On Wed, Jul 29, 2015 at 5:26 PM, Tom van Tilburg
> <tom.van.tilburg at gmail.com <mailto:tom.van.tilburg at gmail.com>> wrote:
>     Hi Ahmet,
>     It depends on how you would like to have the values returned.
>     If it's an average (or some other kind of statistics) I think you
>     need a two step approach:
>     1) Clip the raster where it intersects with the polygon:
>     http://postgis.net/docs/RT_ST_Clip.html
>     2) Do you stats on the resulting clipped image:
>     http://postgis.net/docs/RT_ST_SummaryStats.html
>     Hope this helps,
>         Tom
>     On 7/27/2015 4:16 PM, Ahmet Temiz wrote:
>>      Hello,
>>     How can we get raster values of a map that intersects with
>>     certian part of a polygon map ?
>>      regards
>>     Ahmet Temiz
>>     Jeoloji Müh.
>>     Afet ve Acil Durum Yönetimi Başkanlığı
>>     Bilgi İşlem  Dairesi Başkanlığı-CBS Grubu
>>     ________________________
>>     Ahmet Temiz
>>     Geological Eng.
>>     Information Systems - GIS Group
>>     Disaster and Emergency Management
>>     of Presidency
>>     _______________________________________________
>>     postgis-users mailing list
>>     postgis-users at lists.osgeo.org  <mailto:postgis-users at lists.osgeo.org>
>>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> *with regards*
> *K. Kishore Raju*
> **/BE,// ME,M.Tech,(Ph.D)./
> *Asst. Professor IT Dept,*
> *S.R.K.R Engg. College,*
> *Bhimavaram, W.G.Dt, *
> *AP,India-534202*
> *Contact No: 09949844004*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150803/dc82f9c6/attachment.html>
