[postgis-users] Postgis doesn't work after search_path
franco base
frenk.calza at gmail.com
Tue Aug 4 01:07:44 PDT 2015
Hi Sandro,
Your select returns public (8 rows).
But i just solved restarting the server.
Thanks a lot.
FB
2015-08-04 9:56 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> On Tue, Aug 04, 2015 at 09:21:56AM +0200, franco base wrote:
> > Postgis is in Public Schema
> > I run
> > ALTER DATABASE mydb SET search_path TO 'test'
> > After Postgis doesn't work
> This is expected.
> > So I give this command
> > reset search_path
> > and then
> > alter database mydb set search_path = "$user", public, topology
> > This select:
> > SELECT r.rolname, d.datname, rs.setconfig
> > FROM pg_db_role_setting rs
> > LEFT JOIN pg_roles r ON r.oid = rs.setrole
> > LEFT JOIN pg_database d ON d.oid = rs.setdatabase
> > show that mydb is now ok and the setconfig is the same for all the db:
> > "{"search_path=\"$user\", public, topology"}"
> > On the other db Postgis is ok but on 'mydb' postgis doesn't work again.
> > This is the error (it's the same for all postgis function):
> > ERROR: function st_union(public.geometry) does not exist
> > LINE 33: select st_union(wkb_geometry) AS wkb_geometry
> > Have you any tips?
> show search_path;
> select n.nspname from pg_namespace n, pg_proc p where p.proname =
> 'st_union' and n.oid = p.pronamespace;
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150804/122eee2e/attachment.html>
