[postgis-users] pgr_drivingdistance problem
James Keener
jim at jimkeener.com
Fri Aug 28 17:45:45 PDT 2015
When I run |pgr_drivingdistance|
<http://docs.pgrouting.org/2.0/en/src/driving_distance/doc/dd_driving_distance.html>
on an small extract (578 rows) (attached) from an extract of
Pennsylvania's osm pbf file
<http://download.geofabrik.de/north-america/us/pennsylvania.html> not
all edges are being followed. I first downloaded the pbf. Then I
imported it with |osm2pgrouting|
<https://github.com/pgRouting/osm2pgrouting> |
osmosis --read-pbf file=pennsylvania-latest.osm.pbf --write-xml pennsylvania-latest.osm
osm2pgrouting -file pennsylvania-latest.osm -conf /usr/share/osm2pgrouting/mapconfig.xml -dbname osm3 -user jim -skipnodes -passwd hunter2
| and then running |
CREATE TABLE smallways AS
SELECT * FROM ways
WHERE ST_DISTANCE(the_geom, ST_GEOMFROMTEXT('POINT(-79.900121 40.448889)', 4326)) < 0.2;
| and creating the appropriate indices to build a test environment (the
output of which is the small extract (578 rows)(attached)). To test
|pgr_drivingdistance|, I did the following: |
CREATE OR REPLACE VIEW testing AS
SELECT gid,
the_geom
FROM ( SELECT
seq,
id1 AS vertext_id,
id2 AS gid,
cost
FROM pgr_drivingdistance(
'SELECT gid AS id, source, target,
length AS cost, reverse_cost
FROM smallways',
179103,
0.5,
false,
true) ) t
INNER JOIN smallways USING (gid);
| and then loading that view into QGIS, I see the following:
<cid:part5.06050408.08070207 at jimkeener.com>
Why are some edges not being selected? I initially thought it was the
|(source, target)| (labels in screenshot) ordering, but that doesn't
seem to be the case, as some edges such as 148517 to the SW of the
annotated starting point, seems to be in good order. |
Jim
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150828/22aa7231/attachment.html>
Name: Screenshot - 08282015 - 07:57:32 PM.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150828/22aa7231/attachment.jpg>
Name: Screenshot - 08282015 - 07:57:32 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150828/22aa7231/attachment.png>
Type: application/x-bzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150828/22aa7231/attachment.bin>
