[postgis-users] Unit testing a PostGIS function
Adrien ANDRÉ
adr.andre at laposte.net
Thu Dec 3 07:25:49 PST 2015
Hi all,
for simple code, appart from the main project, how may i perform unit
testing?
Looking at the source code structure [1], i wrote a simple function,
some queries using it and produced expected outputs to the following files:
├── function.sql
└── regress
├── function_expected
└── function.sql
Not at ease with complex makefiles and not knowing the Perl language, i
simply tried comparing
psql -t -A -f regress/function.sql -o function_output
with
function_expected
using diff...
Is there a better way?
Thank you for any suggestion,
kind regards,
Adrien
[1] https://trac.osgeo.org/postgis/browser/trunk/regress
