[postgis-users] Any native compression strategies suited for a revisioning system?
Peter Devoy
peter at 3xe.co.uk
Sun Dec 13 09:09:49 PST 2015
Hi Nicklas
Just read the spec. of TWKB and it sounds very promising. Great
recommendation, many thanks for your help.
Kind regards
Peter
*3XE <http://3xe.co.uk/>* P: 01326 567155 M: 07770 693662 A: 3XE Ltd
Tremough Innovation Centre
PENRYN
TR10 9TA 3XE Ltd · Registered in England and Wales · 9356871
On 13 December 2015 at 16:55, nicklas.aven <nicklas.aven at jordogskog.no>
wrote:
> Hi
> You could take a look at the twkb format. There is encoder (ST_AsTWKB) and
> decoder (ST_GeomFromTWKB) in PostGIS since version 2.2. Twkb can be stored
> as bytea in the database.
> HTH
> Nicklas Avén
> Sent from my Samsung device
> -------- Original message --------
> From: Peter Devoy <peter at 3xe.co.uk>
> Date: 13/12/2015 15:47 (GMT+01:00)
> To: postgis-users at lists.osgeo.org
> Subject: [postgis-users] Any native compression strategies suited for a
> revisioning system?
> I have been tasked with creating a revisioning system for geometries
> stored by PostGIS. To avoid data duplication I thought about storing
> only diffs but because that introduces other complications I am
> thinking about just storing each revision in its entirety and having a
> compression mechanism minimize size on disk.
> However, it seems to me that, quite rightly, Postgres's compression
> algorithm (PGLZ?) is not optimised for delta encoding or high
> compression ratios. So are there any options short of me implementing
> user-defined functions to wrap a compression library?
> For clarity, with this method I am thinking each geometry would have a
> corresponding row in which a field would hold all revisions in a JSON
> data structure.
> Peter
> postgis-users mailing list
> http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151213/407f5579/attachment.html>
