[postgis-users] Errors restoring a db
Birgit Laggner birgit.laggner at ti.bund.de
Tue Dec 22 05:33:07 PST 2015
You don't have to use postgres user per se - but the user using the
'copy' command has to be a superuser. Perhaps it might be easier to
change your own user role accordingly?
Am 22.12.2015 um 14:25 schrieb Paolo Cavallini:
> Il 22/12/2015 14:21, Humberto Cereser Ibanez ha scritto:
>> Hi Paolo,
>> If your sql is trying to use 'copy' command, I experencied that the
>> superuser postgres can run it and stop the errors that you showed.
> I see, thanks. Not very nice to be forced using postgres though.
> All the best.
