[postgis-users] Possible for ST_Intersects to not include the perimeter?
Paragon Corporation
lr at pcorp.us
Mon Feb 2 10:58:59 PST 2015
What is the spatial reference system of your data. If it’s in degrees, your areas are all going to be all < 1. You’d have to go with something like 0.0001 or cast your data to geography when you do the check
e.g. assuming your srid is 4326
select ST_Asgeojson( geom ) from table where ST_Intersects(ST_GeomFromGeoJSON('$state'), geom)=TRUE and ST_Area(ST_Intersection(ST_GeomFromGeoJSON('$state')::geography, geom::geography))>1
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Joseph Spenner
Sent: Monday, February 02, 2015 1:31 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Possible for ST_Intersects to not include the perimeter?
Chris:
I've been trying to get your suggestion to work as well, but appear to be having some problem with the syntax.
I currently have a situation where I have a polygon completely inside of a state, as well as a couple on the border.
I have a query, but it returns ZERO:
select ST_Asgeojson( geom ) from table where ST_Intersects(ST_GeomFromGeoJSON('$state'), geom)=TRUE and ST_Area(ST_Intersection(ST_GeomFromGeoJSON('$state'), geom))>1
I have been using the following, with pretty good success:
select ST_Asgeojson( geom ) from table where ST_Intersects(ST_GeomFromGeoJSON('$state'), geom)=TRUE and ST_Touches(ST_GeomFromGeoJSON('$state'), geom)=FALSE
But sometimes, there seems to be a really tiny square centimeter of area which makes the above succeed, so I would like to have at least some value to describe "how much intersection?" there is. But even using a small value (1), it always makes my select return no rows.
Ideas?
Thanks!
Regardds,
Joseph Spenner
_____
From: Christopher Swingley <cswingle at swingleydev.com <mailto:cswingle at swingleydev.com> >
To: Joseph Spenner <joseph85750 at yahoo.com <mailto:joseph85750 at yahoo.com> >
Cc: PostGIS Users Discussion <postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org> >
Sent: Wednesday, January 21, 2015 4:58 PM
Joseph,
On Wed, Jan 21, 2015 at 2:34 PM, Joseph Spenner <joseph85750 at yahoo.com <mailto:joseph85750 at yahoo.com> > wrote:
> I have NWS polygons describing Thunderstorm Warnings, which are made up of
> counties within the state. Some of those counties might be on the edge of
> the state. I want to query my database to show me all Warnings which are in
> a supplied state. However, if I query the adjacent state which borders the
> counties from the first state, I get those Warnings because they share the
> same parimeter points.
What about finding the states that intersect thunderstorm warnings
where the intersection area is greater than some small threshold?
Something like:
ST_Intersects(warning_geom, state_geom) AND
ST_Area(ST_Intersection(warning_geom, state_geom)) > 1000
Cheers,
Chris
Fairbanks, Alaska
http://swingleydev.com/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150202/54208de9/attachment.html>
