[postgis-users] Creating a DBlink to load data from Oracle Spatial to PostGIS
Vincent Picavet - ML vincent.ml at oslandia.com
Thu Feb 5 14:14:23 PST 2015
Hello,
Le jeudi 29 janvier 2015, 15:22:15 Tahir Tamba a écrit :
> Otherwise, are there another ways to load tables from Oracle Spatial
> database to PostGIS ?
As Brent suggested, you can use Oracle Foreign Data Wrapper. There is now full
support for Oracle spatial included in Oracle_fdw natively and without
dependency.
Once setup, you can access your Oracle tables from within PostgreSQL/PostGIS
transparently, and can use materialized views on foreign table if you want a
cache mechanism to improve performances.
This is AFAIK the most performant way to do, and totally transparent from an
application point of view.
https://github.com/laurenz/oracle_fdw
Note that ora2pg (since version 14) can generate directly the oracle_fdw
foreign tables, or completely migrate your data :
http://ora2pg.darold.net/news.html
Thanks to Laurenz, Gilles and Vincent for this work.
Vincent
Vincent Picavet - Gérant Oslandia
www.oslandia.com
