[postgis-users] Getting TopologyExections when trying to node linestrings to create an overlay
Sandro Santilli
strk at keybit.net
Mon Feb 9 03:25:25 PST 2015
On Tue, Feb 03, 2015 at 11:28:35AM -0500, BladeOfLight16 wrote:
> https://drive.google.com/file/d/0B_6I7kRgE8teVUpha2Q4ZlNDMWs/view?usp=sharing.
> DO $$
> DECLARE problem_row error_generating_polygons%ROWTYPE;
> BEGIN
> FOR problem_row IN (SELECT * FROM error_generating_polygons) LOOP
> BEGIN
> PERFORM ST_Union(ST_Boundary(geom))
> FROM UNNEST(problem_row.polygons) p (geom);
> RAISE NOTICE 'geom_set_id % succeeded', problem_row.geom_set_id;
> EXCEPTION
> WHEN OTHERS THEN
> RAISE NOTICE 'Error for geom_set_id % (Code %): %',
> problem_row.geom_set_id, SQLSTATE, SQLERRM;
> END;
> END LOOP;
> END
First of all I confirm it still happens with GEOS="3.5.0dev-CAPI-1.9.0 r4038".
Second, I took a look at a random set (geom_set_id=1) and I found it pretty
big. That's to say you could probably further reduce the dataset for the
ticket. That set contains 109 polygons, I can get the error by attempting
to union the boundaries of the first 40 in that set, and I'm sure you can
further reduce the input.
So my suggestion:
1) file the ticket
2) attach the _smallest_ input that reproduces the problem
About ST_IsValid: lines are always valid, so there's no need to test.
Most likely this is a robustness issue failing to deal with very close
but not equal lines.
NOTE: I've tried my reduced input (~40) geoms against the topology builder
and it also resulted in errors, until I specified a tolerance of 1e-4.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
