[postgis-users] Topology & Attributes
Ofer Zilberstein zilberstein.ofer at gmail.com
Mon Feb 9 05:52:24 PST 2015
Hi Nicolas,
1. I used  ST_CreateTopoGeo()  to build the topology (not the
topology.toTopoGeom()
as you mentioned )
When I look at the relation table its empty ? should I use
instead, and it will populate it ?
2. can you explain what the parentheses (special the 1, ...) part mean...
join pe.parcelle p1 on *(1, (p1.topo).id)* = (r1.layer_id, r1.topogeo_id)
Thanks in advanced ...
Ofer
On Mon, Feb 9, 2015 at 11:05 AM, Nicolas Ribot <nicolas.ribot at gmail.com>
wrote:
> Hi,
> As usual with SQL, there must be several other ways to perform the same
> query.
> As the edge view stores 2 faces id per row (left and right), I duplicated
> the joins to join both left_face and right face against the original
> polygon table (p1 and p2 aliases)
> Nicolas
> On 8 February 2015 at 21:57, Ofer Zilberstein <zilberstein.ofer at gmail.com>
> wrote:
>> Much Thanks,
>> First I will try to understand the join that you did and then try to
>> implement it...
>> Ofer
>> On Sun, Feb 8, 2015 at 12:44 PM, Nicolas Ribot <nicolas.ribot at gmail.com>
>> wrote:
>>> Hi,
>>> When you build the topology, for instance with topology.toTopoGeom(),
>>> you get back a TopoGeometry object for each polygon added to the topology.
>>> This TopoGeometry is used to keep a link between your polygon object and
>>> all the topological elements composing it.
>>> The "relation" table inside the topo schema holding the topology
>>> contains the identifier of the topoGeometry object and the identifiers of
>>> topo elements composing the polygon.
>>> To get the right and left original polygons from the topology, you make
>>> a join between edge, relation and pg table:
>>> (topo_grass is the topo schema, parcelle is the polygon table with a
>>> topo column containing the TopoGeometry object corresponding to the
>>> polygon):
>>> select e.edge_id, e.left_face, e.right_face,
>>>   p1.id as left_id, p2.id as right_id
>>> from topo_grass.edge e
>>>   join topo_grass.relation r1 on r1.element_id = e.left_face
>>>   join pe.parcelle p1 on (1, (p1.topo).id) = (r1.layer_id, r1.topogeo_id)
>>>   join topo_grass.relation r2 on r2.element_id = e.right_face
>>>   join pe.parcelle p2 on (1, (p2.topo).id) = (r2.layer_id, r2.topogeo_id);
>>> Nicolas
>>> On 8 February 2015 at 10:29, Ofer Zilberstein <
>>> zilberstein.ofer at gmail.com> wrote:
>>>> Hi,
>>>> When you build topology from set of connected polygons, the original
>>>> polygon attributes are not part of the topology model. The model creates
>>>> MBR face for each original polygon.
>>>> The edges hold the left & right faces.
>>>> How or what is the right way to add to the edges the right and left
>>>> original polygons ?
>>>> *Ofer Zilberstein*
>>>>     Mobile: 972-544886873
>>>>     Skype: ofer.zilberstein
>>>>     Mail: zilberstein.ofer at gmail.com
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> *Ofer Zilberstein*
*Ofer Zilberstein*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150209/0c0c4086/attachment.html>
