[postgis-users] [OFF-TOPIC] SQL question
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Feb 18 19:06:04 PST 2015
I have an interesting join problem that I'm not sure how to tackle in sql.
I have two tables that I need to join (well really match) like this:
create table a (
gid serial,
item text,
data text
create table b (
gid serial,
item text,
moredata text
gid can be used to force correct ordering of the records.
item can be one or more rows with the same value in it (for example
there might be 10 item='foo' records)
data and more data is stuff related to the given record.
What I know is that:
1. if table a has N rows for a given item then table b will have N rows
2. that the N rows in table a and table b are in the same order by gid
3. it is not safe to assume that a.gid=b.gid will link the correct records
What I need is to match/join is:
a.item.row[1] to b.item.row[1]
a.item.row[2] to b.item.row[2]
a.item.row[N] to b.item.row[N]
where a.item=b.item
Any thoughts on how to solve this with SQL?
select aa.item, aa.cnt, bb.cnt
from (select item, count(*) as cnt from a group by item) aa
left outer join (select item, count(*) as cnt from b group by item) b
on aa.item=bb.item
order by aa.item;
So likewise, we should be able to do something like:
select aa.item, aa.data, bb.moredata
from (select item, data from a order by item, gid) aa
left outer join (select item, moredata from b order by item, gid) b
on aa.item=bb.item and a.itemrow=b.itemrow
order by aa.item;
This needs some way of assigning itemrow numbers that can be matched. I
think this is an application of over() but I'm not quite sure how to
apply it.
Thoughts would be appreciated :)
Thanks,
-Steve
