[postgis-users] overlapping geometries
Hugues François hugues.francois at irstea.fr
Thu Feb 26 06:08:18 PST 2015
Hello,
I’m not sure I understand your whole problem, but I can try to give you the beginning of some answers :
-          The use of ST_Overlaps seems more natural to me to find overlapping geometries (it depends on what you’re looking for, and you may also have look to ST_Intersects but ST_Contains does not return the same kind of results)
-          To compare geometries within a single layer, you can make an auto jointure and a select distinct to remove duplicates. Something like this query may work :
SELECT DISTINCT a.* FROM table AS a, table AS b
WHERE a.gid != b.gid  and ST_Overlap(a.geom, b.geom)
HTH
Hugues.
De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de volker.emmel at lwk-rlp.de
Envoyé : jeudi 26 février 2015 14:33
À : postgis-users at lists.osgeo.org
Objet : [postgis-users] overlapping geometries
hey list,
i have the following problem:
- i have overlapping geometries in one layer in my postgis (8.3) database.
-> how could i find the overlapping geometries??
->i could not divide into two layers...
-> if i have two layers i could use st_contain, but in one ??
- it will be over 6 million geometries....
any idea?
thanks
vollbtz
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150226/f9b5477a/attachment.html>
