[postgis-users] PostGIS 1.5.3-2 Help: ST_ConvexHull ( ST_Collect ( points from a join table
Domenico Giusti
dncgst at gnewarchaeology.it
Fri Feb 27 11:24:36 PST 2015
Dear list,
I have two tables and I need help:)
* table_record with a 3d polygon geom
id, primary key
code,
geom
* table_record_point with a 3d point geom
id, primary key
code, reference table_record(code)
x,
y,
z,
geom
The relation is one-to-many, as one record could have one or more points.
I would like to update record.geom with a ConvexHull 3d polygon
collecting points from record_point.geom for some records.
I can print out the geom_hull:
SELECT p.code,
ST_ConvexHull(ST_Collect(p.geom)) AS geom_hull
FROM record_point AS p WHERE p.code = 'D19C5P05'
GROUP BY p.code;
but I miss the way to join the tables and update the record.geom.
Thanks for any help!
Domenico Giusti <dncgst at gnewarchaeology.it>
GPG keyID: 2048R/A3AB7054F6E5D778
