[postgis-users] ST_Intersects ST_GeomFromGeoJSON syntax
Hugues François
hugues.francois at irstea.fr
Wed Jan 7 00:17:10 PST 2015
Hello,
I'm not very familiar with the use of ST_GeomFromGeoJSON() but looking at the doc, it only accepts a single json string so you'd better remove all the ST_GeomFromText stuff: ST_GeomFromGeoJSON($jsonPolys). There are some examples at the bottom of the page http://www.postgis.org/docs/ST_GeomFromGeoJSON.html.
HTH
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at lists.osgeo.org de la part de Joseph Spenner
Date: mar. 06/01/2015 20:31
À: PostGIS Users Discussion
Objet : [postgis-users] ST_Intersects ST_GeomFromGeoJSON syntax
Hello,I currently have a select which works correctly:
$sth = $dbh->prepare("select ST_Asgeojson( geom ) from polys where ST_Intersects(ST_GeomFromText('POLYGON(($textPoly, $closingLon $closingLat))', 4269), geom)=TRUE");
I'm trying to do the same thing, using FromGeoJSON instead of Text. Below is my attempt, but it's not working. This is my statement, where $jsonPolys contains the JSON:
$sth = $dbh->prepare("select ST_Asgeojson( geom ) from polys where ST_Intersects(ST_GeomFromGeoJSON('POLYGON(($jsonPolys))', 4269), geom)=TRUE");
I think the problem has something to do with the POLYGON text, since it may not be necessary. But I can't get the syntax right.
Any ideas?
Thanks!
Regards,Joseph Spenner
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150107/87e32292/attachment.bin>
