[postgis-users] Issues with compiling PostGIS 1.5.8 on FreeBSD
Paragon Corporation
lr at pcorp.us
Mon Jan 19 02:19:18 PST 2015
Paul,
Which version of PostGIS did you use the 1.5.3 or 1.5.8?
Thanks,
Regina
-----Original Message-----
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of
mista_pink at web.de
Sent: Monday, January 19, 2015 4:50 AM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Issues with compiling PostGIS 1.5.8 on FreeBSD
Dear Regina,
I "fixed" this by setting up an VM with old FreeBSD and compiled PostGIS
there. I copied the library to the updated system and the backup worked.
Cheers,
Paul
Am 19.01.2015 um 03:52 schrieb Paragon Corporation:
> Paul,
>> pg_dump: Error message from server: ERROR: Unknown geometry type:
> -1099038720 - Unknown
> Sadly doesn't work if you don't have a working database which it
> sounds like you've got 1.5 data with 2.1 binaries. Kindof a mess.
>> So my best idea was to pull 1.5.3 (most recent used by ports) and
>> 1.5.8
> (most recent available from source),
>> go through the files from
> http://svn.freebsd.org/ports/tags/RELEASE_9_2_0/databases/postgis/ and
> try to find the needed flags etc.
> Well if we assume 1.5.3 worked and that is the last FreeBSD used, I
> would compile with 1.5.3. All the older source tarballs are here
> http://download.osgeo.org/postgis/source/
> In case you didn't know.
> It's just as easy to hard upgrade from 1.5.3 as it is from 1.5.8 so no
> real benefit using 1.5.8 if you plan to migrate to 2.1 anyway.
> It's quite possible we broke 1.5.8 on FreeBSD and given few people are
> using
> 1.5 and none of the PostGIS dev team has a dev box running FreeBSD, we
> would have missed the break unless FreeBSD package maintainers
> complained (which they did when we broke 2.1 on FreeBSD :) ).
> Hope that helps,
> Regina
> http://www.postgis.us
> http://postgis.net
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
