[postgis-users] Possible for ST_Intersects to not include the perimeter?
Joseph Spenner
joseph85750 at yahoo.com
Wed Jan 21 15:34:16 PST 2015
Pete: Thanks for the reply! But I just tried, and ST_Contains will miss if the alert polygon spans multiple states. I have an example which spans a bit of California and Arizona. When I select AZ or CA, I get nothing back. So it appears, as the documentation states, ST_Contains will only return true if all of the points in "A" are completely inside "B".
From: Pete Yunker <peter.yunker at homejunction.com>
To: Joseph Spenner <joseph85750 at yahoo.com>; PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Sent: Wednesday, January 21, 2015 3:17 PM
Subject: Re: [postgis-users] Possible for ST_Intersects to not include the perimeter?
I believe you want ST_Contains. Using sample Census TIGER data for states and counties:
SELECT COUNT(c.*)FROM prod.states sINNER JOIN prod.counties cON (s.name = 'Georgia'AND ST_Contains(s.the_geom, c.the_geom));--159
SELECT COUNT(*) from prod.counties WHERE state_cd = 'GA';--159
I suppose it's possible that the NWS polygons aren't using the exact same county/boundary border as your reference states boundaries. As such, you could also use a slight negative buffer on the NWS polygons to further ensure that they don't overlap an adjacent state border.
Regards,Pete Yunker
On Jan 21, 2015, at 5:01 PM, Joseph Spenner <joseph85750 at yahoo.com> wrote:
For the record, my best guess (which didn't work) was:
select ST_Asgeojson( geom ) from polys where ST_Intersects(ST_GeomFromGeoJSON('$jsonPoly'), geom)=TRUE and ST_Touches(ST_GeomFromGeoJSON('$jsonPoly'), geom)=FALSE
Since 'touch' seemed to be the way to address the perimeter points. But apparently this is not the case.
To: "postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
Sent: Wednesday, January 21, 2015 2:22 PM
Subject: Possible for ST_Intersects to not include the perimeter?
I have a polygon as an input, and I'm trying to find all polygons which share points, but not the perimiter points themselves. Is this possible?
Real application: I have NWS polygons describing Thunderstorm Warnings, which are made up of counties within the state. Some of those counties might be on the edge of the state. I want to query my database to show me all Warnings which are in a supplied state. However, if I query the adjacent state which borders the counties from the first state, I get those Warnings because they share the same parimeter points.
Is there a way to construct a query which will not return anything if the only points in common are the perimeter values themselves?
I tried a few variations on ST_Intersects/ST_Covers/ST_Contains/ST_Overlaps, supplying various AND/OR and TRUE/FALSE combinatins, but I can't seem to get the right combo to accomplish my task.
Any help would be great.
Thanks!
Regards,Joseph Spenner
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150121/59235c42/attachment.html>
