[postgis-users] Checking Road Network Topology
toni hernández
toni at sigte.udg.edu
Fri Jan 23 01:46:43 PST 2015
Sandro,
At this point I am not sure. :-(
I tried again using srid=4326 and a tolerance of 0.0001 which for my
latitud (Girona, Spain) is about 1 meter.
This time everything worked just fine.
This are the SQL statements adapted from
http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html
SELECT topology.DropTopoGeometryColumn('public', 'streets_4326',
'topogeom'); --Topology created with 0 tolerance by default
SELECT topology.droptopology('streets_4326_topo');
-- Exercici de topologia amb coordenadas geogràfiques.
SELECT topology.CreateTopology('streets_4326_topo', 4326);
SELECT topology.AddTopoGeometryColumn('streets_4326_topo', 'public',
'streets_4326', 'topogeom', 'MULTILINESTRING');
SELECT streets_4326_geomTotopo();
Where streets_4326_geomTotopo() is not a very good function but good
enough for testing :
CREATE OR REPLACE FUNCTION streets_4326_geomTotopo()
RETURNS void AS
$BODY$
DECLARE r record;
BEGIN
FOR r IN SELECT * FROM streets_4326 LOOP
BEGIN
UPDATE streets_4326 SET topogeom = topology.toTopoGeom(geom,
'streets_4326_topo', 1, 0.0001) -- 0.0001º around 1 meter)
WHERE id = r.id;
EXCEPTION
WHEN OTHERS THEN
RAISE WARNING 'Loading of record % failed: %', r.id, SQLERRM;
END;
END LOOP;
END;
$BODY$ LANGUAGE plpgsql volatile;
On 22/01/2015 21:53, Sandro Santilli wrote:
> On Thu, Jan 22, 2015 at 04:13:44PM +0100, toni hernández wrote:
>> Steve,
>> I had the same issue when working with geometries using srid=4326 .
>> I was also following the same link (http://blog.mathieu-leplatre.info/use-postgis-topologies-to-clean-up-road-networks.html)
>> Then I tried with some projected geometries (units = meters) and the
>> problem was gone. I am not sure why. Maybe it was just a
>> coincidence.
> Can it be you're specifying a too large of a precision for your
> topologies in srid=4326 ?
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
