[postgis-users] Import TIN via SQL COPY from file
Hillier, Michael Michael.Hillier at NRCan-RNCan.gc.ca
Thu Jun 4 12:53:13 PDT 2015
Hello,
I am trying to import a TIN surface into postgresql + postgis database from a file via an SQL COPY command.
First off, here is my table:
CREATE TABLE tintable(id int4 primary key, geom geometry(TIN,4326));
Because the TIN data is too large (thousands of entries) I can not use the  command
INSERT INTO tintable (id,geom) VALUES (1,ST_GeomFromText('TIN(((1 0,0 1,1 1,1 0)))',4326));
So I use the following:
COPY tintable FROM 'C::\\users\\...' DELIMITERS '|'
I have tried the following formats in the file I am trying to copy from:
1|(0 0,0 1,1 1,0 0) -> ERROR:  parse error - invalid geometry HINT:  "(0" <-- parse error at position 2 within geometry
1|0 0,0 1,1 1,0 0 -> ERROR:  Invalid hex string, length (15) has to be a multiple of two! CONTEXT:  COPY tintable, line 1, column geom: "0 0,0 1,1 1,0 0"
1|((0 0,0 1,1 1,0 0)) -> ERROR:  parse error - invalid geometry HINT:  "((" <-- parse error at position 2 within geometry
What is the correct file format so I can import TIN data using the command "COPY tintable FROM 'C::\\users\\...' DELIMITERS '|' "?
Thank you
