[postgis-users] Problem creating a trigger using ST_Union?
KhunSanAung
khunsanaung.gis at gmail.com
Mon Jun 8 05:25:52 PDT 2015
Hi All,
I'd like to create a trigger that will
update the dissolve layer when there is any change on a polygon layer.
I need a dissolve layer (big polygon) to get the boundary of all small
polygons layer.
But not able to get it successfully yet.
My PGSQL trigger code is as below.
------------------------- CODE Start------------------
-- Function: public.a_dissolve_trigger_func()
-- DROP FUNCTION public.a_dissolve_trigger_func();
CREATE OR REPLACE FUNCTION public.a_dissolve_trigger_func()
RETURNS trigger AS
$BODY$
BEGIN
UPDATE public.a_polygon_dissolve
SET
geom = ST_Union(geom)
where a_polygon_dissolve.gid=1;
END;
$BODY$
LANGUAGE plpgsql VOLATILE
COST 100;
ALTER FUNCTION public.a_dissolve_trigger_func()
OWNER TO postgres;
-- Trigger: a_dissolve_trigger on public.a_polygon
-- DROP TRIGGER a_dissolve_trigger ON public.a_polygon;
CREATE TRIGGER a_dissolve_trigger
AFTER INSERT OR DELETE OR UPDATE
ON public.a_polygon
FOR EACH ROW
EXECUTE PROCEDURE public.a_dissolve_trigger_func();
---------------------------------------- END OF CODE -------
When I tried to modified the input polygon in QGIS,
the error message says 'aggregate function - ST_Union() is not allowed in
Update as below.
--------------- error message start --------------------
Could not commit changes to layer a_polygon
Errors: ERROR: 1 feature(s) not added.
Provider errors:
PostGIS error while adding features: ERROR: aggregate functions are not
allowed in UPDATE
LINE 3: geom = ST_Union(geom)
QUERY: UPDATE public.a_polygon_dissolve
SET
CONTEXT: PL/pgSQL function a_dissolve_trigger_func() line 3 at SQL statement
----------------- error message end ----------------------
*Question 1.*
*If someone could suggest a better method dissolving layer in trigger, it
would be very helpful for me.*
I search and found some methods for creating a dissolve polygon.
When I select the geom by Union, as follow
SELECT ST_Union(geom) AS geom FROM a_polygon;
Query returned successfully: one row affected,
I can see the geometry values in output result.
But When I tried to write the result into a new dissolve table as follow;
SELECT ST_Union(geom) AS geom INTO a_polygon_dissolve
FROM a_polygon GROUP BY geom;
The layer is not visible when I tried to connect using QGIS.
I cannot open that file using QGIS.
Sometimes (testing with other polygon layers) the geom column is blank and
I cannot open the newly form 'a_polygon_dissolve' file in QIGS too.
I'd tried to add a primary key, 'gid' column but it doesn't work.
In this case, I need to drop the 'dissolve polygon' first in order to write
a new file.
*Question 2.*
*If this is the option to use the ST_Union, how can I fix the above
geometry problem ?*
I'm using, postgres-9.3 and postgis-2.1 version in Window OS version.
The input 'a_polygon' as text is below.
------------- input 'a_polygon' as text --------------
"st_astext"
"MULTIPOLYGON(((96.1484380679014 16.781203891314,96.1507922871521
16.7810815942101,96.1505171186682 16.777748998128,96.1505022713357
16.7777492102328,96.1483769193495 16.777779572404,96.1484380679014
16.781203891314)))"
"MULTIPOLYGON(((96.1507922871521 16.7810815942101,96.1507922871521
16.7810815942101,96.152657317987 16.7810510199341,96.1523821495031
16.777779572404,96.1505171186682 16.777748998128,96.1507922871521
16.7810815942101)))"
"MULTIPOLYGON(((96.152657317987 16.7810510199341,96.1540178732682
16.7810357327961,96.1538497147503 16.77788658237,96.1523821495031
16.777779572404,96.152657317987 16.7810510199341)))"
"MULTIPOLYGON(((96.1540178732682 16.7810357327961,96.1555465870673
16.7810815942101,96.1554242899634 16.7781006023018,96.1538497147503
16.77788658237,96.1540178732682 16.7810357327961)))"
---------------- end of text ------------------
Thank you very much for any idea.
Have a nice day!
*Mr. Khun San Aung*
* <http://geoportal.icimod.org/>*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150608/c81df242/attachment.html>
