[postgis-users] error adding data into ArcGIS
David Fawcett david.fawcett at gmail.com
Mon Jun 8 19:15:04 PDT 2015
Mark,
I ran into this recently, but can't remember what caused it. I will look back and see if I can remember. Maybe wrong SRS, null geometries?
David
> On Jun 8, 2015, at 4:29 PM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> All the sudden I am getting an error loading data into ArcGIS:  “One or more layers failed to draw:  lyongis.public.parcels:  The specified coordinate exceeds the valid coordinate range”
> The script (below) that I used in the past always had worked fine.  So I am not sure where to begin.  QGIS works fine.  I am using ArcGIS 10.3 with Postgres 9.2
> Sincerely,
> Mark Volz, GISP
> Lyon County GIS Coordinator
> Script to load data into PostGIS.
> set PATH=C:\Program Files\PostgreSQL\9.2\bin;%PATH%
> cd /d "D:\PostGISIncoming\LyonGIS"
> rem load data to postgis
> for %%f in (*.shp) do shp2pgsql -d -I -s 103749 -W LATIN1 %%f %%~nf | psql -w -U postgres -d lyongis
> for %%a in (*.*) do move "%%a" "D:\PostGISIncoming\LyonGIS\Done"
> cd /d "D:\PostGISIncoming"
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150608/93a59276/attachment.html>
