[postgis-users] Get only the main river. Smoothline???
toni hernández
toni at sigte.udg.edu
Tue Jun 9 06:04:11 PDT 2015
thanks Hugues,
The thing is that with st_Dump I get all the linestrings of a river but
there is no way (that I know of) that I can order all the segments and
get the "real" start /end points of the whole river.
*Toni Hernández Vallès*
Servei de Sistemes d'Informació Geogràfica i Teledetecció
Universitat de Girona
*SIGTE*
Pl. Ferrater Mora 1
17071 Girona
Tel +34 972 418 039 (7026 intern)
toni at sigte.udg.edu <mailto:toni at sigte.udg.edu>
http://www.sigte.udg.edu
Twitter http://twitter.com/SIGTE_UDG
On 09/06/2015 08:56, Hugues François wrote:
> Hello,
> I think ST_Dump could help to deal with multilinestrings:
> http://postgis.net/docs/ST_Dump.html
> Hugues.
> *De :*postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] *De la part de* toni
> hernández
> *Envoyé :* mardi 9 juin 2015 08:09
> *À :* postgis-users at lists.osgeo.org
> *Objet :* Re: [postgis-users] Get only the main river. Smoothline???
> Thanks Remi,
> I thought that but I have no starting/ending points. St_StartPoint and
> St_EndPoint are not working with MultiLinestrings
> I'll give it some more intense thought. :)
> Cheers.
> *SIGTE*
> Pl. Ferrater Mora 1
> 17071 Girona
> On 08/06/2015 17:45, Rémi Cura wrote:
> if you have start and end point of geom B,
> you can get the river path with a shortest path method (one liner
> using python, can be done in few hours using plpgsql).
> The idea is that you cut your geom into segments(pairs of points)
> , the length of the segment is the weight of this edge
> , and you know which segment is connected to which segment
> (adjacency graph).
> Then you use Networkx
> <http://networkx.lanl.gov/reference/generated/networkx.algorithms.shortest_paths.generic.shortest_path.html#networkx.algorithms.shortest_paths.generic.shortest_path>shortest
> path distance.
> Else,
> you are up to use some nasty workaround I suppose (playing with
> buffers on your original river surface, testing which segment
> intersects etc. ).
> I tried that but it ends up being more work (and more corner
> cases) than doing the things properly (in my experience).
> Cheers,
> Rémi-C
> 2015-06-08 16:42 GMT+02:00 toni hernández <toni at sigte.udg.edu
> <mailto:toni at sigte.udg.edu>>:
> Hi everyone,
> I have a multilinestring with a river and all its afluents as you
> can see in this image
> http://sigserver4.udg.edu/apps/geometries.png
> I got geometry A using St_StraithSkeleton.
> Is there a way to go from geometry A to geometry B??
> Maybe something similar to SmoothLine???
> *SIGTE*
> Pl. Ferrater Mora 1
> 17071 Girona
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150609/a3a4d2a2/attachment.html>
