[postgis-users] Problem creating a trigger using ST_Union?
KhunSanAung
khunsanaung.gis at gmail.com
Tue Jun 9 06:51:08 PDT 2015
Thank you very much ,
inserting the aggregate values into the dissolve table by trigger is what I
want.
The sql command below works well as I wanted to.
-- Function: public.a_dissolve_trigger_func()
-- DROP FUNCTION public.a_dissolve_trigger_func();
CREATE OR REPLACE FUNCTION public.a_dissolve_trigger_func()
RETURNS trigger AS
$BODY$
BEGIN
DELETE FROM a_polygon_dissolve
WHERE gid>0;
INSERT INTO public.a_polygon_dissolve (geom)
SELECT ST_Union(geom) AS geom FROM a_polygon ; --GROUP BY geom ;
RETURN NEW;
END;
$BODY$
LANGUAGE plpgsql VOLATILE
COST 100;
ALTER FUNCTION public.a_dissolve_trigger_func()
OWNER TO postgres;
-- Trigger: a_dissolve_trigger on public.a_polygon
-- DROP TRIGGER a_dissolve_trigger ON public.a_polygon;
CREATE TRIGGER a_dissolve_trigger
AFTER INSERT OR DELETE OR UPDATE
ON public.a_polygon
FOR EACH ROW
EXECUTE PROCEDURE public.a_dissolve_trigger_func();
I've used INSERT instead of UPDATE.
I create a dissolve layer for the first time and it get updated by trigger
all the time.
Thank you very much again for your explanation and help
Best regards
On Mon, Jun 8, 2015 at 10:06 PM, Rémi Cura <remi.cura at gmail.com> wrote:
> Hey,
> you must think in term of geometry and not layer,
> because the function you use works on geometry and not layer.
> For instance
> UPDATE public.a_polygon_dissolve SET geom = ST_Union(geom)
> where ...
> will take one row by one row, and for each row geometry (geomA), compute
> st_union(geomA),
> which is obviously not what you want.
> On the opposite,
> SELECT ST_Union(geom) AS geom FROM a_polygon;
> will take all the row from a_polygon, and compute the union of all the row
> geom.
> You can use CTE within INSERT to emulate that
> (e.g.
> WITH to_insert AS (
> --do my computing
> SELECT ...
> INSERT INTO ...
> USING ...
> Anyway, I can't understand what you are trying to do .
> What you call 'not visible' in qgis is simply that you can't access it
> from the regular menu because QGIS can't understand it.
> This is because you didn't specified the type of geometry you are
> producing, and don't have a primary key or unique row id.
> creating the table like this
> SELECT ST_Union(geom) AS geom INTO a_polygon_dissolve
> FROM a_polygon GROUP BY geom;
> is a bad idea.
> You should use
> -------not so clean- ----
> SELECT row_number() over() as example_of_unique_id,
> ST_Union(geom)::geometry(polygon,4326) AS geom INTO a_polygon_dissolve
> -- OR (very clean)
> CREATE TABLE public.a_polygon_dissolve (
> gid serial,
> geom geometry(polygon,4326)
> SELECT ST_Union(geom) AS geom INTO a_polygon_dissolveFROM a_polygon GROUP BY
> geom
> Cheers,
> Rémi-C
> 2015-06-08 14:25 GMT+02:00 KhunSanAung <khunsanaung.gis at gmail.com>:
>> Hi All,
>> I'd like to create a trigger that will
>> update the dissolve layer when there is any change on a polygon layer.
>> I need a dissolve layer (big polygon) to get the boundary of all small
>> polygons layer.
>> But not able to get it successfully yet.
>> My PGSQL trigger code is as below.
>> ------------------------- CODE Start------------------
>> RETURNS trigger AS
>> $BODY$
>> BEGIN
>> SET
>> where a_polygon_dissolve.gid=1;
>> END;
>> $BODY$
>> COST 100;
>> OWNER TO postgres;
>> ON public.a_polygon
>> FOR EACH ROW
>> ---------------------------------------- END OF CODE -------
>> When I tried to modified the input polygon in QGIS,
>> the error message says 'aggregate function - ST_Union() is not allowed in
>> Update as below.
>> --------------- error message start --------------------
>> Could not commit changes to layer a_polygon
>> Errors: ERROR: 1 feature(s) not added.
>> Provider errors:
>> PostGIS error while adding features: ERROR: aggregate functions are not
>> allowed in UPDATE
>> LINE 3: geom = ST_Union(geom)
>> QUERY: UPDATE public.a_polygon_dissolve
>> SET
>> CONTEXT: PL/pgSQL function a_dissolve_trigger_func() line 3 at SQL
>> statement
>> ----------------- error message end ----------------------
>> *Question 1.*
>> *If someone could suggest a better method dissolving layer in trigger,
>> it would be very helpful for me.*
>> I search and found some methods for creating a dissolve polygon.
>> When I select the geom by Union, as follow
>> Query returned successfully: one row affected,
>> I can see the geometry values in output result.
>> But When I tried to write the result into a new dissolve table as follow;
>> The layer is not visible when I tried to connect using QGIS.
>> I cannot open that file using QGIS.
>> Sometimes (testing with other polygon layers) the geom column is blank
>> and I cannot open the newly form 'a_polygon_dissolve' file in QIGS too.
>> I'd tried to add a primary key, 'gid' column but it doesn't work.
>> In this case, I need to drop the 'dissolve polygon' first in order to
>> write a new file.
>> *Question 2.*
>> *If this is the option to use the ST_Union, how can I fix the above
>> geometry problem ?*
>> I'm using, postgres-9.3 and postgis-2.1 version in Window OS version.
>> The input 'a_polygon' as text is below.
>> ------------- input 'a_polygon' as text --------------
>> "st_astext"
>> "MULTIPOLYGON(((96.1484380679014 16.781203891314,96.1507922871521
>> 16.7810815942101,96.1505171186682 16.777748998128,96.1505022713357
>> 16.7777492102328,96.1483769193495 16.777779572404,96.1484380679014
>> 16.781203891314)))"
>> "MULTIPOLYGON(((96.1507922871521 16.7810815942101,96.1507922871521
>> 16.7810815942101,96.152657317987 16.7810510199341,96.1523821495031
>> 16.777779572404,96.1505171186682 16.777748998128,96.1507922871521
>> 16.7810815942101)))"
>> "MULTIPOLYGON(((96.152657317987 16.7810510199341,96.1540178732682
>> 16.7810357327961,96.1538497147503 16.77788658237,96.1523821495031
>> 16.777779572404,96.152657317987 16.7810510199341)))"
>> "MULTIPOLYGON(((96.1540178732682 16.7810357327961,96.1555465870673
>> 16.7810815942101,96.1554242899634 16.7781006023018,96.1538497147503
>> 16.77788658237,96.1540178732682 16.7810357327961)))"
>> ---------------- end of text ------------------
>> Thank you very much for any idea.
>> Have a nice day!
>> *Mr. Khun San Aung*
>> * <http://geoportal.icimod.org/>*
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Have a nice day!
*Mr. Khun San Aung*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150609/31372038/attachment.html>
