[postgis-users] Find unique date and code values before applying st_intersects
Gery .
gamejihou at hotmail.com
Fri Jun 12 07:42:57 PDT 2015
Thanks a lot Andy, I just got right the first query:
select distinct to_date(fecha,'DD/MM/YY') as fecha,matricula_embarcacion from temporada1erapesca2012_point_wgs84 order by matricula_embarcacion;
but the second one is not working:
select cuadro_produce_region.gid,cuadro_produce_region.area,cuadro_produce_region.zona,cuadro_produce_region.cod,count(*) from cuadro_produce_region inner join (select distinct to_date(fecha,'DD/MM/YY'),matricula_embarcacion from temporada1erapesca2012_point_wgs84 order by matricula_embarcacion) as tmpPtos on (tmpPtos.fecha = cuadro_produce_region.fecha);ERROR: column tmpptos.fecha does not exist
LINE 1: ...84 order by matricula_embarcacion) as tmpPtos on (tmpPtos.fe...
and this is because there is no "fecha" in "cuadro_produce_region". INNER JOIN would work better than ST_intersects in this case? I mean, I need to find all points inside each region (10 regions) of the polygon table (ie. cuadro_produce_region), and st_intersects works well in the query below:
select cuadro_produce_region.gid,cuadro_produce_region.area,cuadro_produce_region.zona,cuadro_produce_region.cod,count(*) as Nro from temporada1erapesca2012_point_wgs84,cuadro_produce_region where (temporada1erapesca2012_point_wgs84.velocidad between '0.2' and '1.6') and st_intersects(cuadro_produce_region.geom,temporada1erapesca2012_point_wgs84.geom) group by cuadro_produce_region.gid order by cuadro_produce_region.gid,cuadro_produce_region.cod;
> Date: Thu, 11 Jun 2015 16:53:46 -0500
> From: andy at squeakycode.net
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] Find unique date and code values before applying st_intersects
> On 6/11/2015 3:36 PM, Gery . wrote:
>> Hello,
>> I have two tables, one containing polygons and one with points:
>> # polygons
>> gid | integer | not null default
>> nextval('cuadro_produce_region_gid_seq'::regclass)
>> id | character varying(10) |
>> zona | character varying(10) |
>> area | character varying(10) |
>> cod | double precision |
>> seccion | double precision |
>> ordxdistc | double precision |
>> geom | geometry(PolygonZM,4326) |
>> # points
>> nombre_embarcacion | character varying(150) |
>> matricula_embarcacion | character varying(150) |
>> tipo_casco | character varying(150) |
>> capacidad_bodega | character varying(150) |
>> nombre_aparejo | character varying(150) |
>> descripcion_proveedor | character varying(150) |
>> fecha | character varying(150) |
>> longitud | numeric |
>> latitud | numeric |
>> velocidad | numeric |
>> rumbo | numeric |
>> ts | tsvector |
>> geom | geometry(Point,4326) |
>> Finding all points, first filtered by velocity ("velocidad" field),
>> inside each region was quite easy:
>> select
>> '1.6') and
>> but now I need to select unique values from fields "fecha" and
>> "matricula_embarcacion" of the table
>> 'temporada1erapesca2012_point_wgs84' first and then apply the
>> intersection with the 'cuadro_produce_region' table, I tried "distinct"
>> in the where clause with no success so far:
>> select
>> '1.6' and
>> distinct(temporada1erapesca2012_point_wgs84.matricula_embarcacion) and
>> distinct(temporada1erapesca2012_point_wgs84.fecha)) and
>> how could I do this query? "fecha" field has this structure: 16/06/2012
>> 03:00
>> Any hints are welcomed, thanks in advance,
> Your first email had much better formatting.
> Start with the first thing, select it out, then wrap it into a derived
> table.
> so first:
> select distinct fecha, matricula_embarcacion
> If that returns to you the right data, then expand it:
> select whatever
> inner join (
> ) as tmpPoints on (tmpPoints.fecha = cuadro_produce_region.fecha)
> -Andy
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
