[postgis-users] Shp2pgsql not found in Centos 7 64 bit
Kis János Tamás
kijato at gmail.com
Mon Jun 15 00:46:09 PDT 2015
I don't know Centos.
I don't use Postgresql from packages, because it isn't perfect never (its
my experience...). Always I compile Postgresql-Postgis from source and I'm
happy.
In my opinion when the maintainer made the postgis package doesn't put the
shp2pgsql / pgsql2shp program to the package.
This problem is independent that you can to run postgis_full_version SQL
function and there isn't shp2pgsql, that is a "additional" binary software,
isn't SQL function.
I guess you must try to complie & install & use postgresql-postgis from
source... or must wait that Centos Team improving the mistake.
Or: compile postgresql-postgis from source and copy the shp2pgsql /
pgsql2shp to the /usr/local/bin (for example).
Greetings,
kjt
2015.06.12. 1:48 ezt írta ("Luciano" <br.analistagis at gmail.com>):
> Hello, I installed postgis in a server Centos 7 using the 'yum install
> postgis2_94' command, but shp2pgsql does not run.
> When I search the existing shortcut in '/usr/bin/shp2pgsql', it points to
> /etc/alternatives/ postgis-shp2pgsql ',
> what points to' /usr/postgresql-9.4/bin/shp2pgsql ' what does not exist.
> In short, when I run './usr/bin/shp2pgsql' or
> '/usr/postgresql-9.4/bin/shp2pgsql' get command not found.
> For installation, I used the following repositories:
> http://yum.postgresql.org/9.4/redhat/rhel-7-x86_64/pgdg-centos94-9.4-1.noarch.rpm
> http://dl.fedoraproject.org/pub/epel/7/x86_64/e/epel-release-7-5.noarch.rpm
> After the installation, with the comand: #select postgis_full_version(), I
> get:
> POSTGIS="2.1.7...
> That is, apparently, everything is normal...
> This would be a bug of de install script?
> Some suggestion ...?
> Thanks.
> Luciano
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150615/3f9bc803/attachment.html>
