[postgis-users] Computing the lenght of a building's edges looking on a direction
Paolo Crosato
paolo.crosato at targaubiest.com
Thu Jun 18 07:39:54 PDT 2015
Thank you very much! I'll try with this approach.
Regards,
Paolo
Il 17/06/2015 18:24, Rémi Cura ha scritto:
> Hm,
> quite easy normally (method proposed above won't work).
> First break your polygon into segment, for instance with
> https://github.com/Remi-C/PPPP_utilities/blob/master/postgis/rc_DumpSegments.sql
> Then, for each segment, compute the angle between first and last
> point, using |ST_Azimuth, and st_pointN.
> |Now, keep the segment where the abs(angle) is between pi/2
> -tolerancy and pi/2+tolerancy
> ( you should add a tolerancy , nobody will be facing exactly north)*.
> |*Now simply sum the st_length of found segments.
> |*Cheers,
> |*Rémi-C
> 2015-06-17 17:40 GMT+02:00 Komяpa <me at komzpa.net <mailto:me at komzpa.net>>:
> Hello,
> you can apply ST_ForceRHR, break your polygons into segments and
> sum length of the ones that go from right to left, that is, where
> ST_X(ST_StartPoint(geom)) < ST_X(ST_StartPoint(geom)).
> That's basically visibility problem, been there somewhere around
> https://github.com/Komzpa/Mapnik-Sheets/blob/master/3d-buildings/3dbuil.xml#L95
> 2015-06-17 18:12 GMT+03:00 Paolo Crosato
> <paolo.crosato at targaubiest.com
> <mailto:paolo.crosato at targaubiest.com>>:
> Hi,
> I have a set of 2d polygons representing buildings. For each
> one, I have to find the lenght of the edges that look towards
> north.
> Here http://imgur.com/HgpO2yH there is a small picture with a
> test case, I have to compute the lenght of the red edges.
> Has anybody any suggestion on how to do this in postgis?
> Thanks for any input,
> Regards
> Paolo Crosato
> Software engineer/Custom Solutions
> e-mail: paolo.crosato at targaubiest.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Darafei "Komяpa" Praliaskouski
> OSM BY Team - http://openstreetmap.by/
> xmpp:me at komzpa.net <mailto:xmpp%3Ame at komzpa.net>
> mailto:me at komzpa.net <mailto:me at komzpa.net>
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Paolo Crosato
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150618/dcf68cf7/attachment.html>
