[postgis-users] Problem in 3Dcitydatabase importer/exporter
Felix Kunde felix-kunde at gmx.de
Mon Jun 29 08:49:10 PDT 2015
Hey Dimitra
Did you receive any errors during the import?
Are you sure you are using the correct reference system in the DB?
Are you using the newest version of the 3DCityDB?
You could send me the model and I could check it out myself, if you want.
Felix
Gesendet: Montag, 29. Juni 2015 um 15:30 Uhr
Von: Dimitra <dimitradimitra at windowslive.com>
An: postgis-users at lists.osgeo.org
Betreff: [postgis-users] Problem in 3Dcitydatabase importer/exporter
Hello,
I create a building model(LOD 3) in sketch up pro and then i transformed it
into gml format via FME. Despite the fact that, in FME Inspector and FZK
Viewer the building model is displayed fine, when i import it in 3D
citydatabase importer/exporter and export it in kml/collada file something
goes wrong. Specifically, the model is not displayed in the right position,
some building parts are missing and the textures are lost. Do you know why
this happens? I am waiting for your reply!! Thanks in advance!!!
View this message in context: http://postgis.17.x6.nabble.com/Problem-in-3Dcitydatabase-importer-exporter-tp5008524.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users[http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users]
