[postgis-users] Problem in 3Dcitydatabase importer/exporter
dimitra dimitra
dimitradimitra at windowslive.com
Tue Jun 30 04:52:29 PDT 2015
To: postgis-users at lists.osgeo.org
Subject: RE: [postgis-users] Problem in 3Dcitydatabase importer/exporter
Date: Tue, 30 Jun 2015 14:46:34 +0300
Hello Felix,
Thank you for your reply. I am using the newest version of 3Dcitydatabase and during the import, there are no errors. I have been experimenting with the coordinate system but with no result. However, the main problem is that all building parts and textures do not been displayed. I am sending to you the gml file, if you want to check it out. Thank you anyway for your interest.
> From: felix-kunde at gmx.de
> CC: postgis-users at lists.osgeo.org
> Date: Mon, 29 Jun 2015 17:49:10 +0200
> Subject: Re: [postgis-users] Problem in 3Dcitydatabase importer/exporter
> Hey Dimitra
> Did you receive any errors during the import?
> Are you sure you are using the correct reference system in the DB?
> Are you using the newest version of the 3DCityDB?
> You could send me the model and I could check it out myself, if you want.
> Felix
> Gesendet: Montag, 29. Juni 2015 um 15:30 Uhr
> Von: Dimitra <dimitradimitra at windowslive.com>
> An: postgis-users at lists.osgeo.org
> Betreff: [postgis-users] Problem in 3Dcitydatabase importer/exporter
> Hello,
> I create a building model(LOD 3) in sketch up pro and then i transformed it
> into gml format via FME. Despite the fact that, in FME Inspector and FZK
> Viewer the building model is displayed fine, when i import it in 3D
> citydatabase importer/exporter and export it in kml/collada file something
> goes wrong. Specifically, the model is not displayed in the right position,
> some building parts are missing and the textures are lost. Do you know why
> this happens? I am waiting for your reply!! Thanks in advance!!!
> View this message in context: http://postgis.17.x6.nabble.com/Problem-in-3Dcitydatabase-importer-exporter-tp5008524.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users[http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150630/5d3878e1/attachment.html>
