[postgis-users] median center instead of st_centroid
Steve.Toutant at inspq.qc.ca
Thu Mar 12 11:43:06 PDT 2015
Wow merci Remi. That saves me a lot of coding...
Rémi Cura <remi.cura at gmail.com>@lists.osgeo.org
Envoyé par : postgis-users-bounces at lists.osgeo.org
2015-03-12 12:42
Veuillez répondre à
PostGIS Users Discussion <postgis-users at lists.osgeo.org>
A
cc
Objet
Re: [postgis-users] median center instead of st_centroid
Hey,
what you want is extremely easy to get.
First add the median function to your database from here
(Now you have access to median(numeric) )
Then,
for a table my_table containing points in the geom column
--not tested
SELECT ST_MakePoint(median(ST_X(geom)), median(ST_Y(geom))) as
my_median_point
FROM my_table
Cheers,
Rémi-C
2015-03-12 14:56 GMT+01:00 <Steve.Toutant at inspq.qc.ca>:
I used st_centroid on a multipoint table to get the mean center.
I would like to compare the result on the median center
http://en.wikipedia.org/wiki/Center_of_population#Mean_center
Is there already an operator in postgis that does that?
Otherwise I would like to write one, but I don't have much experience
doing that, so any tips on how to do that well would be appreciated
Thanks in advace for your help!
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150312/6905013e/attachment.html>
