[postgis-users] error installing postgis on linux
Sandro Santilli
strk at keybit.net
Fri Mar 13 05:47:24 PDT 2015
On Fri, Mar 13, 2015 at 08:08:51AM -0400, Maria L. Wilson wrote:
> I am installing postgis on a linux box and am getting the following
> error on the make install part - any help would be appreciated!
> cp: cannot create regular file `/usr/local/lib/_inst.11278_':
> Permission denied
You do not have permissions to create files under /usr/local/lib.
Ask your system administrator to install it for you or give you
permissions.
Some administrators (or default install) give powers via the "sudo"
command, which lets you run a command as if you were an administrator.
If that's the case, it will work with:
sudo make install
Give it a try
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
