[postgis-users] Quick/unobstrusive way to determine if a geometry has curve elements?
Andrea Aime andrea.aime at geo-solutions.it
Tue May 5 01:52:25 PDT 2015
I have some generic build of code that are building queries to postgis
includingthe st_simplify function, e.g:
select st_simplify(geometry, tolerance) from mytable where ...
This is done to optimize data transfer and overall performance when doing
map rendering, we just get the
geometries as "complex" as we need them to.
However, I've found out that the function does not support curved
geometries, all will throw an error if it
encounters one of them, e.g.:
> select st_simplify(geometry, 0.1) from curves;
ERROR:  lwgeom_simplify: unsupported geometry type: CircularString
Curved geometries are often representing a small percentage of the
geometries, so I would like
to keep on simplifying the geometries made of straight segments, while
skipping simplification
on the curved ones, so I'm looking for a way to quickly and unobstrusively
check if geometry
has curved portions inside of it.
So far I've come up with this, but it's not simple, unobstrusive, probably
not so fast due to string
comparisons, and not general (what if I stumble into a geometry collection
that does contain
curve elements for example?):
select case geometrytype(geometry) when 'CIRCULARSTRING' then geometry
         when 'COMPOUNDCURVE' then geometry
         when 'CURVEPOLYGON' then geometry
         when 'MULTISURFACE' then geometry
         when 'MULTICURVE' then geometry
         else st_simplify(geometry,0.1)
         end
from curves;
Can anybody suggest a better way, that would not require us to have the end
user tell
us if a table mixes in curve bits, or not?
Cheers
Andrea
http://goo.gl/NWWaa2 for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150505/02622f9a/attachment.html>
