[postgis-users] Query plan improvement when identical st_intersects filter is repeated twice
Trang Nguyen Trang.Nguyen at inrix.com
Wed May 20 17:53:00 PDT 2015
I am tuning query performance on the  following query and am seeing two completely different query plans for the following. The only difference is that the second query repeats the same filter “st_intersects(waypoints, zone_geom)” a second time, which somehow  seems to trigger an index scan on the gist indexed LINESTRING column “waypoints” that doesn’t occur in the first query.
I’ve run analyze on the table so DB stats are current.
View:
REATE OR REPLACE VIEW od1.v_trip_zone AS
 SELECT z.uuid AS zone_id,
    z.name AS zone_name,
    z.namespace AS zone_namespace,
    z.geom AS zone_geom,
        CASE
            WHEN st_intersects(t.startloc, z.geom) AND st_intersects(t.endloc, z.geom) THEN 2
            WHEN st_intersects(t.startloc, z.geom) THEN 0
            WHEN st_intersects(t.endloc, z.geom) THEN 1
            WHEN st_intersects(t.waypoints, z.geom) THEN 3
            ELSE (-1)
        END AS match_cond,
    t.pkey,
    t.trip_id,
    t.startts,
    t.endts,
    t.startloc,
    t.endloc,
    t.probe_id,
    t.provider_id,
    t.movement_type,
    t.mode,
    t.trip_dist_m,
    t.trip_mean_speed_metersph,
    t.trip_max_speed_metersph,
    t.is_start_home,
    t.is_end_home,
    t.waypoints,
    t.createdts
   FROM od1.trip_v1_partitioned t,
    od1.zone z;
Query 1:
select pkey, trip_id, startts, endts, startloc, endloc, probe_id, provider_id, movement_type, mode, trip_dist_m, trip_mean_speed_metersph, trip_max_speed_metersph, is_start_home, is_end_home, waypoints from od1.v_trip_zone  where zone_id in ('kansas_303','kansas_601','kansas_603','kansas_604','kansas_10','kansas_11','kansas_9','kansas_310','kansas_311','kansas_315','kansas_301','kansas_302','kansas_307','kansas_306','kansas_305','kansas_204','kansas_201','kansas_3','kansas_2','kansas_1')
and st_intersects(waypoints, zone_geom)
and startts>=TIMESTAMP '2015-01-16' and endts<TIMESTAMP '2015-01-31'   and startts<TIMESTAMP '2015-01-31'
order by pkey
limit 2
Plan:
"Limit  (cost=82.43..1774.34 rows=2 width=1257)"
"  ->  Nested Loop  (cost=82.43..120241818.53 rows=142137 width=1257)"
"        Join Filter: ((t.waypoints && z.geom) AND _st_intersects(t.waypoints, z.geom))"
"        ->  Merge Append  (cost=0.70..7242945.66 rows=21320513 width=1257)"
"              Sort Key: t.pkey"
"              ->  Index Scan using trip_partitioned_v1_pkey on trip_v1_partitioned t  (cost=0.12..8.15 rows=1 width=216)"
"                    Filter: ((startts >= '2015-01-16 00:00:00'::timestamp without time zone) AND (endts < '2015-01-31 00:00:00'::timestamp without time zone) AND (startts < '2015-01-31 00:00:00'::timestamp without time zone))"
"              ->  Index Scan using trip_v1_y2015m01_pkey on trip_v1_y2015m01 t_1  (cost=0.56..6976431.09 rows=21320512 width=1257)"
"        ->  Materialize  (cost=81.73..154.02 rows=20 width=9864)"
"              ->  Bitmap Heap Scan on zone z  (cost=81.73..153.92 rows=20 width=9864)"
"                    Recheck Cond: ((uuid)::text = ANY ('{kansas_303,kansas_601,kansas_603,kansas_604,kansas_10,kansas_11,kansas_9,kansas_310,kansas_311,kansas_315,kansas_301,kansas_302,kansas_307,kansas_306,kansas_305,kansas_204,kansas_201,kansas_3,kansas_ (...)"
"                    ->  Bitmap Index Scan on idx_uuid  (cost=0.00..81.72 rows=20 width=0)"
"                          Index Cond: ((uuid)::text = ANY ('{kansas_303,kansas_601,kansas_603,kansas_604,kansas_10,kansas_11,kansas_9,kansas_310,kansas_311,kansas_315,kansas_301,kansas_302,kansas_307,kansas_306,kansas_305,kansas_204,kansas_201,kansas_3,kan (...)"
Query 2 (Much improved):
and st_intersects(waypoints, zone_geom) and st_intersects(waypoints, zone_geom)
order by pkey
limit 2
Plan:
"Limit  (cost=333.74..333.75 rows=2 width=1257)"
"  ->  Sort  (cost=333.74..333.86 rows=47 width=1257)"
"        Sort Key: t.pkey"
"        ->  Nested Loop  (cost=81.73..333.27 rows=47 width=1257)"
"              ->  Append  (cost=0.00..8.95 rows=2 width=736)"
"                    ->  Seq Scan on trip_v1_partitioned t  (cost=0.00..0.00 rows=1 width=216)"
"                          Filter: ((startts >= '2015-01-16 00:00:00'::timestamp without time zone) AND (endts < '2015-01-31 00:00:00'::timestamp without time zone) AND (startts < '2015-01-31 00:00:00'::timestamp without time zone) AND (waypoints && z.geom) (...)"
"                    ->  Index Scan using idx_trip_v1_y2015m01_waypoints on trip_v1_y2015m01 t_1  (cost=0.42..8.95 rows=1 width=1257)"
"                          Index Cond: ((waypoints && z.geom) AND (waypoints && z.geom))"
"                          Filter: ((startts >= '2015-01-16 00:00:00'::timestamp without time zone) AND (endts < '2015-01-31 00:00:00'::timestamp without time zone) AND (startts < '2015-01-31 00:00:00'::timestamp without time zone) AND _st_intersects(waypoi (...)"
Could someone shed some light on the difference in query planner results?
Thanks,
Trang
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150521/562ecb22/attachment.html>
