[postgis-users] coordinate order of geometry vs coordinate order of gml
Rushforth, Peter
Peter.Rushforth at NRCan-RNCan.gc.ca
Mon May 25 13:59:58 PDT 2015
I am confused by coordinate order issues that I noticed when using qgis for the first time today.
I have a table with a geometry column that stores different shapes - points, lines and polygons.
The projection of the column is EPSG:4326 ->
"(f_table_catalog)";"(f_table_schema)";"(f_table_name)entrystore";"(f_geometry_column)georss_where";(coord_dimension)2;(srid)4326;"(type)GEOMETRY"
When I access the column using qgis, and apparently with pgsql2shp, the coordinate order of the geometry column is reversed / incorrect.
When I access the column with ST_AsGML, it is correct. When I access with ST_AsKML, it reverses the coordinate order:
select ST_AsKML(georss_where), ST_AsGML(georss_where) from entrystore where updatetimestamp = 914103->
"<Polygon><outerBoundaryIs><LinearRing><coordinates>46,-76 45,-76 45,-74 46,-74 46,-76</coordinates></LinearRing></outerBoundaryIs></Polygon>";"<gml:Polygon srsName="EPSG:4326"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>46,-76 45,-76 45,-74 46,-74 46,-76</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon>"
Am I wrong in thinking that either ST_AsGML or ST_AsKML has got something wrong? I would have expected that PostGIS, knowing the geometry is EPSG:4326,
would return the KML in lon,lat order.
When I take the centroid of the geometry and report it with ST_AsLatLonText it reports longitude and latitude reversed, when compared with the GML:
select ST_AsLatLonText(ST_centroid(georss_where)), ST_AsGML(ST_Centroid(georss_where)) from entrystore where updatetimestamp = 914103
"75°0'0.000"S 45°30'0.000"E";"<gml:Point srsName="EPSG:4326"><gml:coordinates>45.5,-75</gml:coordinates></gml:Point>"
Thank you.
Peter Rushforth
P.S.
I noticed that on this documentation page there are two coordinate orders for apparently a similar area in North America (?) - EPSG:4269, but
perhaps this is unrelated.
http://postgis.net/docs/ST_GeomFromGML.html
