[postgis-users] RE Best projection srid for topology
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Wed May 27 10:11:29 PDT 2015
UTM covers the earth, could you generate the 120 zones and translate
data...
I don't know after it is usable for topology......
Marc-André Goderre <magoderre at cgq.qc.ca>@lists.osgeo.org
Envoyé par : postgis-users-bounces at lists.osgeo.org
2015-05-27 13:00
Veuillez répondre à
PostGIS Users Discussion <postgis-users at lists.osgeo.org>
A
cc
Objet
Re: [postgis-users] RE  Best  projection srid for topology
That's the problem. I use the whole planet road data. I' can't use UTM or
MTM meter srid.
Thanks
Marc
De : postgis-users-bounces at lists.osgeo.org [
mailto:postgis-users-bounces at lists.osgeo.org] De la part de
Envoyé : 27 mai 2015 12:56
À : PostGIS Users Discussion
Cc : postgis-users-bounces at lists.osgeo.org
Objet : [postgis-users] RE Best projection srid for topology
If you need to translate to meter I think you should avoid 3857 if you
need precision on linear or surface measure.
It depend where on earth you are....
2015-05-27 11:32
Veuillez répondre à
A
"postgis-users at lists.osgeo.org" <postgis-users at lists.osgeo.org>
cc
Objet
[postgis-users] Best  projection srid for topology
Hello all,
I'm working on a many million lines topology project with OSM data in 4326
srid. I'd like to know if i should transform their geom in a meter srid (
like 3857). Should it be faster for the 'toTopoGeom()' function to work
with geometry in 4326 or in 3857 srid?
Thanks
Marc
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20150527/28def569/attachment.html>
