[postgis-users] postgis_restore.pl
Paul & Caroline Lewis paulcaz80 at hotmail.com
Thu May 28 12:30:16 PDT 2015
Great, thanks, I'll try this 1st thing in the morning.
Just to note the 2.0 version was only at RC1 stage when we built the original LiDAR platform.
Paul
--- Original Message ---
Sent: 28 May 2015 20:22
To: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] postgis_restore.pl
For 2.0->2.1 restore you should be able to use pg_restore directly on
the dump file, no need to filter it through the postgis_restore.pl
file...
P
On Thu, May 28, 2015 at 8:58 AM, Paul & Caroline Lewis
<paulcaz80 at hotmail.com> wrote:
> Hi,
>   I'm trying to restore after a Hard upgrade from Postgresql 9.0 and PostGIS
> 2.0SVN to Postgresql 9.3 with Postgis 2.1 and PointCloud.
> The back-up dump went fine and the re-installation of 9.3, 2.1 and
> Pointcloud all fine.
> This is a LiDAR DB and the back-up dump file is 513GB, so its a large
> restore job (I'd imagine).
> Anyway, I've set the following process off:
> sudo perl /usr/share/postgresql/9.3/contrib/postgis-2.1/postgis_restore.pl
> "/storage2/bkup/pg_upgrade.backup" | psql -h localhost -p 5432 -U postgres
> lidar_db 2> errors.txt
> The process gets to:
> Writing manifest of things to read from dump file...
> Writing ASCII to stdout...
> and would seem to be stuck as it has been in this state for over 24 hours.
> Using 'top' I can't see any CPU or MEM values to suggest the process is
> still working, just very busy because of the large file.
> The process creates a new 630kb file called:
> pg_upgrade.backup.lst
> but it is not getting any bigger.
> Basically, should a 500GB+ dump file take hours to restore and should it be
> stuck in this state for so long??
> Where could I look for the problem and what solutions might I try.
> The erros.txt file gets created but its empty 0kb.
> Regards,
> Paul
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
