[postgis-users] SUM on rasters
Stephen Crawford
src176 at psu.edu
Wed Oct 14 07:51:09 PDT 2015
Yes, I figured out I needed to use St_Union()....and also that it can
exceed available memory :-) But after some fine tuning it worked. Thanks.
On 10/14/2015 10:27 AM, Pierre Racine wrote:
> If by "sum" you mean "merge" or "union" use ST_Union(). Be careful as the "sum" can exceed available memory if they are too many rasters in the table.
>> -----Original Message-----
>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>> Behalf Of Stephen Crawford
>> Sent: Monday, October 12, 2015 10:46 AM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] SUM on rasters
>> Hi,
>> I have a table of rasters. I would like to SUM the entire table with
>> one raster as the result. Can somebody point me in to the correct
>> funtion to do this?
>> Thanks,
>> Steve
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
