[postgis-users] RE select raster by pixel value
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Fri Oct 16 09:33:59 PDT 2015
Clearly I misunderstood what the -t 20x20 switch meant in my raster2pgsql
command
I understand now that I have 400 pixels by tile (rid).
I need to intersects all pixel with value = 9 with a multipolygon postgis
layer. I'll see if my sql below will do it
Steve.Toutant at inspq.qc.ca@lists.osgeo.org
Envoyé par : "postgis-users" <postgis-users-bounces at lists.osgeo.org>
2015-10-16 10:41
Veuillez répondre à
PostGIS Users Discussion <postgis-users at lists.osgeo.org>
A
cc
Objet
[postgis-users] select raster by pixel value
First try on using raster in postgis 2.1. I used raster2pgsl to load a
tif.
Then I want to select the rids where pixel value = 9
I ended up with this query
SELECT a.rid,(pvc).value
from test as a
join (SELECT rid,ST_ValueCount(rast) As pvc FROM test) as b ON b.rid =
a.rid and (pvc).value = 9
order by a.rid;
This select returns 28517 records
But using this SQL to get the distinct count i get 1055421 records for
pixel value 9
SELECT (pvc).value, SUM((pvc).count) As total
 FROM (SELECT ST_ValueCount(rast) As pvc
   FROM test) As f
    GROUP BY (pvc).value
order by value;
Obviously there is something I do wrong...
What is it I don't understand?
thanks!
postgis-users mailing list
http://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20151016/cf666acb/attachment.html>
